    Duet3 6HC - controlling mains powered devices
    Using Duet Controllers
    • Nightowlundefined
      Nightowl
      Very new to this in as much as I've not yet got my RatRig CNC machine (due mid March) nor the controller, but I do intend to buy the Duet3D 6HC and have one (of many!) questions, if I may?
      Can the 6HC directly control the on/off function of a dust/chip collector, please, or would I need an add-on board, for example?
      With my old machine I had a relay that activated the chip collector when the router started, but I'm not sure if this function would work with my new machine, which will have a AMB milling motor with a digital interface and controlled by the Duet.
      Thank you
      Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
      I'm still on my learning curve, so take everything I say with caution!
      RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
      Stephen6309undefined 1 Reply Last reply Reply Quote 0
      • Stephen6309undefined
        Stephen6309 @Nightowl
        @nightowl999 You would have to use a relay to control the dust collector.
        Nightowlundefined 1 Reply Last reply Reply Quote 1
        • Nightowlundefined
          Nightowl @Stephen6309
          @stephen6309 Awesome, thank you!
