    Print stops randomly on second layer
    Duet Web Control
    306
    • cjorgensenmdundefined
      cjorgensenmd
      I built a Hevort corexy style printer with a Duet3 and RPi4.
      So far, configuration has all gone smoothly, but once I started actually printing, I ran into issues.
      I've looked through old posts, but cannot find a solution that works.
      My printer will print the first layer just fine, but at random points during the second layer, it just stops and disconnects. Occassionally the progress bar goes straight to 100%. Other times, DWC will not reconnect at all and I need to do a hard reset on the printer.
      Here is M122:
      Connection to Duet established
      2/10/2022, 9:30:47 PM	Warning: Lost connection to Duet (Board is not available (no header response))
      2/10/2022, 9:26:09 PM	M122
      RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-9P63L-DJMSS-6JKDG-3SS6K-KBG7B
      Used output buffers: 1 of 40 (12 max)
      Static ram: 150904
      Dynamic ram: 62336 of which 100 recycled
      Never used RAM 137996, free system stack 152 words
      Tasks: SBC(ready,5.2%,316) HEAT(delaying,0.0%,325) Move(notifyWait,0.1%,252) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,362) CanClock(delaying,0.0%,333) TMC(notifyWait,7.8%,59) MAIN(running,86.8%,922) IDLE(ready,0.0%,29), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 00:23:45 ago, cause: power up
      Last software reset at 2022-02-09 16:36, reason: User, none spinning, available RAM 140852, slot 2
      Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
      Error status: 0x00
      Step timer max interval 735
      MCU temperature: min 11.9, current 24.1, max 24.3
      Supply voltage: min 0.1, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 0.2, current 12.2, max 12.2, under voltage events: 0
      Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/30/30, gc cycles 0
      Driver 0: position 62405, standstill, reads 32391, writes 23 timeouts 0, SG min/max 0/1023
      Driver 1: position -62395, standstill, reads 32391, writes 23 timeouts 0, SG min/max 0/1023
      Driver 2: position 20400, standstill, reads 32391, writes 23 timeouts 0, SG min/max 0/1023
      Driver 3: position 0, standstill, reads 32395, writes 19 timeouts 0, SG min/max 0/267
      Driver 4: position 0, standstill, reads 32396, writes 19 timeouts 0, SG min/max 0/198
      Driver 5: position 0, standstill, reads 32396, writes 19 timeouts 0, SG min/max 0/585
      Date/time: 2022-02-10 15:26:08
      Slowest loop: 168.13ms; fastest: 0.03ms
      === Storage ===
      Free file entries: 10
      DMs created 125, maxWait 158232ms, bed compensation in use: mesh, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 17460, completed moves 17460, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File* is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue* is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages queued 12793, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 7130/0/0
      Tx timeouts 0,51,7129,0,0,5610 last cancelled message type 4514 dest 127
      === SBC interface ===
      State: 4, failed transfers: 2, checksum errors: 185
      Last transfer: 1ms ago
      RX/TX seq numbers: 51168/12636
      SPI underruns 199, overruns 5
      Disconnects: 2, timeouts: 2, IAP RAM available 0x2c83c
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.3.0
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz
      Full transfers per second: 0.63, max wait times: 11.1ms/0.0ms
      Codes per second: 0.07
      Maximum length of RX/TX data transfers: 2888/1544
      Here is my config.g:
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Dec 11 2021 17:06:05 GMT+0100 (Central European Standard Time)
      M550 P"Duet 3"                                     ; set printer name
      M669 K1                                            ; select CoreXY mode
      M569 P0.4 S0                                       ; physical drive 0.4 goes forwards
      M569 P0.5 S0                                       ; physical drive 0.5 goes forwards
      M569 P0.0 S0                                      ; physical drive 0.0 goes forwards
      M569 P0.1 S0                                       ; physical drive 0.4 goes forwards
      M569 P0.2 S0                                       ; physical drive 0.5 goes forwards
      M569 P0.3 S0                                       ; physical drive 0.0 goes forwards
      M584 X0.3 Y0.4 Z0.0:0.1:0.2 E0.5                              ; set drive mapping
      M671 X-26.188:192.521:411.23 Y-17.213:395.997:-17.213 S50; triple z configuration
      M350 X16 Y16 Z16 E16 I1                                ; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z800.00 E550                      ; set steps per mm
      M566 X2900 Y2900 Z30.00  E1000                      ; set maximum instantaneous speed changes (mm/min)
      M203 X50000 Y50000 Z1000.00  E6000                   ; set maximum speeds (mm/min)
      M201 X10000 Y10000 Z100.00   E10000                    ; set accelerations (mm/s^2)
      M906 X2500 Y2500 Z800 I30   E800                         ; set motor currents (mA) and motor idle factor in per cent
      M208 X366 Y395 Z600 S0                             ; set axis maxima
      M574 Z2 S1 P"io1.in+io3.in+io2.in" ; Z axis with three motors, individual max endstops, active high
      M574 Y1 S1 P"io4.in" ; Y endstop at low end
      M574 X1 S1 P"io5.in" ; X endstop at low end
      ;E-stop
      M950 J0 C"!^io0.in" 								   ; create e-stop on pin 0
      M581 P0 T0 C0								   ; create trigger event
      M558 P9 C"io7.in" H5 F100 R0.2 T6000  ; BLTouch connected to Z probe IN pin, free up MOD pin
      M950 S0 C"^io7.out" ; servo/gpio 0 is Z probe MOD pin
      G31 P25 X-18.68 Y52.38 Z2  ...
      M280 P0 S10 ; send control signal to BLTouch through servo/gpio 7                            ; BL touch Z probe but set dive height, probe speed and travel speed
      M557 X25:340 Y60:350 S20                           ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T128000 B3950       ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"temp1" Y"PT1000" T100000 B4138       ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
      M950 F0 C"out4" Q25000                               ; create fan 0 on pin out4 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out7" Q500                               ; create fan 1 on pin out7 and set its frequency
      M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"!out6+^out6.tach" Q450                   ; create fan 2 on pin out6 and set its frequency
      M106 P2 S0 H-1 B0 C"HEVACS"  						   ;set fan 2 values, thermostatic control is turned off
      M950 F3 C"!out5+^out5.tach" Q450                   ; create fan 2 on pin out6 and set its frequency
      M106 P3 S0 H-1 B0  C"HEVACS2"  						   ;set fan 2 values, thermostatic control is turned off
      M563 P0 S"Hotend" D0 H1 F0                                   ; define tool 0
      M501                                               ; load saved parameters from non-volatile memory
      M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      I am on DWC 3.3 and the RPi firmware is on the latest stable build. I tried a solution I saw in another post where the 5v supply is switched to come from the SBC, but that had no effect on the outcome whatsoever.
      Other than when printing, I rarely lose connection. When my duet2 machine loses connection, it just keeps printing, so I'm not too sure what the difference is.
      cjorgensenmdundefined 1 Reply Last reply Reply Quote 0
        cjorgensenmd @cjorgensenmd
        While I'm here, another issue is that only my fan2 and fan3 start a full burst when the board powers on, but after a few seconds they turn off again. Does this have to do with them being Noctua PWM fans and inverted?
        Stephen6309undefined 1 Reply Last reply Reply Quote 0
        • Stephen6309undefined
          Stephen6309 @cjorgensenmd
          @cjorgensenmd The fans will go full on during the startup, but once the config.g is read, they will be set to what's in there. This is a normal occurance. You should start a new topic for different questions.
            Is that M122 from immediately after the board has reset?
              cjorgensenmd @Phaedrux
              @phaedrux I believe so. I'll run another test when I get home in a few hours and redo M122
              • rjenkinsgbundefined
                rjenkinsgb
                A faulty Raspberry Pi is not impossible.
                I had a load of erratic problems with my seconds Duet+Pi machine & after trying everything else, replaced the Pi and all problems disappeared.
                I can only think that it had dodgy RAM that was only causing problems when more tasks were active, as booting up and all basic things like SSH access appeared to work fine - until it got to heavy interactions with the Duet board, then it lost the plot..
                Robert J.
                Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                  cjorgensenmd
                  Unfortunately I lost connection, so I could not get another M122 command
                    Could you please try testing 3.4 RC1 by switching to the unstable package server and doing a sudo apt update and sudo apt upgrade as described here: https://github.com/Duet3D/DuetSoftwareFramework/wiki/SBC-Setup-Guide#unstable-package-feed
                    Do you also have a fresh SD card to test with? SBC mode would likely benefit from a faster card as well.
                      cjorgensenmd
                      That ended up not working. I am assuming a faulty raspberry pi. I am running in standalone mode now until the 8gb Pi 4's are back in stock.
