    First time using duet wifi, nothing working
    2.3k
    • Tininoundefined
      Tinino
      @dc42:
      If your E1 motor output is free, try putting this command in config.g:
      M584 X4 Y1 Z2 E3
      Make sure it is earlier in the file than the M906 command. Then connect your X motor to the E1 motor output.
      If that gets your X axis working, then I'm sorry you do have a bad X driver, and you should ask for your Duet to be replaced or repaired under warranty.
      Are you using 12V or 24V power?
      12v. I've gotta get to bed so I'll give this a shot tomorrow. Thanks for the help.
      • Tininoundefined
        Tinino
        Just a friendly update. Replacement board got here, Runs great now 🙂 absolutely in love.
