    Error: over temperature shutdown reported by driver(s) 2
    278
    • didizundefined
      didiz
      I am having an issue with a CR10 MAX with Duet2 wifi and a volcano installed on it. There are in total of 3 printers with the same configuration in an enclosure passively heated by the heated bed and the ambient temperature is in between 30 and 35 degrees C.
      So one of the printers gave this error and z motors stopped turning ended up in a big mess. I cleaned all, changed the motherboard with another printer that works fine, added another fan so now I have 1 blowing on the back of pcb and other from the side so there is an air flow and the MCU temp stays around 44 45 degrees C even for long prints. Z motor current is 0.7A however the motors get hot. The hottest of all with lowest current.
      I really don't see any reason why this problem persist on the same printer. Can it be caused by cabling in that case the cables of the Z motors I suppose or can it be caused by a motor malfunction ? Please help me in this manner because I am a bit lost...
      For info, I am printing big pieces from PETG taking 20 hours more or less with 28mm3/s with 1mm nozzle so the printers work hard at the moment.
      Thank you so much for your help.
        dc42 administrators @didiz
        @didiz what's the specification of the Z motors; and how have you wired them to the Duet?
        You said that the Z motors get hot; but does the Z driver on the new board also get hot?
        How old is the Duet that reported the over temperature shutdown?
        Please send M906 and M913 without parameters, to check that the Z motor current really is set to 0.7A.
        didizundefined 1 Reply Last reply Reply Quote 0
        • didizundefined
          didiz @dc42
          Hello @dc42
          Thanks for your answer.
          M913
          Motor current % of normal - X:100, Y:100, Z:100, E:100
          M906
          Motor current (mA) - X:850, Y:850, Z:700, E:850, idle factor 30%
          This is the return for the commands.
          Duet is brand new, I bought it 1 month ago and the second board that I have installed is 2 months old.
          I don't know how to check the driver temperature, the MCU temperature is around 45 degrees. I have used the stock cable and cut the duet side connector and crimped the connectors supplied with the board. I have connected them in series (there are 2 slots for Z motors and 2 motors)
          Z motors are the stock creality motors
          Brand: Creality 3D
          Item name: RepRap 42 Stepper Motor
          Item number: 42-34
          Step angle: 1.8 degrees
          Nominal Voltage: 4.83V
          Current Rating: 1.5 (A)
          Rated speed: 1-1000 (rpm)
          Rated torque: 0.4 (NM)
          Ambient Temperatuar: -20℃~+50℃
          Length: 34mm
            @didiz said in Error: over temperature shutdown reported by driver(s) 2:
            Carefully put your finger on it. At 0.7A current, the driver should be no warmer than the rest of the Duet.
            • didizundefined
              didiz @dc42
              @dc42 Hello,
              The driver is not particularly hotter than the rest of the board. I used stock creality cables which was probably not a good idea since I make them work over long periods in an enclosure.
              Could the reason be the cabling for these kind of problems?
              I also had an over voltage error "Warning: VIN over-voltage event (30.5V)
              " on another printer during the night. It cancelled printing. I get these errors very randomly and rarely. However since I have been doing very long prints over and over again with 1 - 2 hours cooling time in between it is hard to understand the problem and very annoying to constantly need to find a solution to save the print.
              didizundefined dc42undefined 2 Replies Last reply Reply Quote 0
              • didizundefined
                didiz @didiz
                Here is the M122 result :
                M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
                Board ID: 0JD0M-9P6M2-NW4SS-6JKD0-3S86J-1BZVL
                Used output buffers: 3 of 24 (15 max)
                Static ram: 23876
                Dynamic ram: 75448 of which 332 recycled
                Never used RAM 11904, free system stack 104 words
                Tasks: NETWORK(ready,65.8%,233) HEAT(delaying,0.6%,330) Move(notifyWait,6.8%,303) MAIN(running,24.6%,445) IDLE(ready,2.2%,29), total 100.0%
                Owned mutexes: WiFi(NETWORK)
                Last reset 12:05:10 ago, cause: power up
                Last software reset at 2022-02-13 20:09, reason: User, GCodes spinning, available RAM 11904, slot 0
                Error status: 0x00
                Step timer max interval 0
                MCU temperature: min 39.4, current 41.1, max 60.6
                Supply voltage: min 24.0, current 24.2, max 30.5, under voltage events: 0, over voltage events: 1, power good: yes
                Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/28/28, gc cycles 0
                Driver 0: position 27090, standstill, SG min/max 0/353
                Driver 1: position 31041, standstill, SG min/max 0/696
                Driver 2: position 25032, standstill, SG min/max not available
                Driver 3: position 0, standstill, SG min/max 0/1023
                Driver 5: position 0
                Driver 6: position 0
                Driver 7: position 0
                Driver 8: position 0
                Driver 9: position 0
                Driver 10: position 0
                Driver 11: position 0
                Date/time: 2022-02-15 08:24:18
                Slowest loop: 128.19ms; fastest: 0.11ms
                === Storage ===
                Free file entries: 10
                SD card longest read time 5.0ms, write time 2.7ms, max retries 0
                DMs created 83, maxWait 375409ms, bed compensation in use: mesh, comp offset 0.000
                === MainDDARing ===
                Scheduled moves 466598, completed moves 466598, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
                === AuxDDARing ===
                Segments left: 0
                Movement lock held by null
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                Daemon is idle in state(s) 0
                Code queue is empty.
                === Filament sensors ===
                Extruder 0 sensor: ok
                === Network ===
                Slowest loop: 140.00ms; fastest: 0.00ms
                HTTP sessions: 1 of 8
                - WiFi -
                Network state is active
                WiFi firmware version 1.26
                WiFi MAC address f4:cf:a2:e2:1b:3e
                WiFi Vcc 3.37, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 25200
                WiFi IP address 192.168.1.110
                WiFi signal strength -74dBm, mode 802.11n, reconnections 0, sleep mode modem
                Clock register 00002002
                  @didiz assuming the Duet that reported the over temperature issues is a genuine one, we will replace it. Please email warranty@duet3d.com including a link to this thread and stating when and from whom you purchased it.
                  Regarding the over-voltage reports: under normal conditions, what VIN voltage does M122 report?
                  didizundefined 2 Replies Last reply Reply Quote 0
                  • didizundefined
                    didiz @dc42
                    @dc42 Thank you so much,
                    I will prepare an e mail.
                    Concerning the over voltage event, this happened to me twice. I couldn't find a documentation with the possible reasons. I can provide you with any information that you need. Is there any known reason to have that very rarely like this?
                    Supply voltage: min 23.9, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                    • didizundefined
                      didiz @dc42
                      @dc42 Just for the information,
                      I restarted the printer that gave over voltage error, secured the piece on the bed and continued printing. It's been 13 hours and still printing. Most of the time I printed in between 105% to 110% and no errors what so ever.
                      Result of actual M122 :
                      Supply voltage: min 24.0, current 24.1, max 24.4, under voltage events: 0, over voltage events: 1, power good: yes
                      So it is very hard to find the source of these kind of errors that don't persist and are very random.
                      Is there anything that comes into your mind ?
                      Thank you so much.
