    Tutorial on how to build and set up a delta printer?
    • Velviaundefined
      Velvia
      I'm building a 350mm delta printer with 500mm arms, but am unsure about a few things, especially setting up firmware correctly. I have a duet 3, smart effector and optical endstops. Is there a guide, video or tutorial on how to connect everything and set up firmware? The wiki is a bit overwhelming to me.
      Homegrown, grass fed and organically built 350mm delta
      • rjenkinsgbundefined
        rjenkinsgb
        Which Duet3 board is it?
        I built a Kossel XL+ based on DC42s design a couple of months ago, using a Duet3 6HC board.
        That has a Smart effector but switches rather than optical endstops - my CoreXY machine has optical though, so I can show the connections for those.
        You are welcome to a copy of the Delta config & photos of the board connections etc., if those are of use?
        Robert J.
        Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
          Have you seen these?
          https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_linear_delta
          https://docs.duet3d.com/en/User_manual/Tuning/Delta_calibration
