    Incorrect fan RPM 3.4RC1 - toolboard
    Beta Firmware
      jay_s_uk
      I'm running this fan Sunon KDE0503PEBX-8 on a v1.1 toolboard as the hotend cooling fan.
      these are the specs
      Fan Manufacturer……………….. Sunon
      Fan Model……………………… KDE0503PEBX-8, KD0503PEBX-8
      Size: Inches…………………….. 1.20. ” X 1.20″ X .236″
      Size: Millimeters………………… 30mm x 30mm x 6mm
      Voltage…………………………. 5 volts DC
      Current………………………….. 0.18A
      Watts…………………………… 0.90
      RPM ……………………………… 9000
      Flow CFM (Max)………………. 5.3
      Noise (dBA)……………………. 29.0
      Bearing Type………………….. Ball Bearing
      Material-Venturi……………… UL94V-0 Plastic
      Material-Propeller…………… UL94V-0 Plastic
      Power Leads………………….. 3- 3″ wires
      Life Expectancy-MTBF……… 50,000 Hours
      The RPM is being reported as approximately double.
        dc42 administrators @jay_s_uk
        @jay_s_uk the new M950 K parameter when creating a fan should allow you to fix this.
