    Configurator won't select Smart Effector
    Config Tool
    • clearlynotstefundefined
      clearlynotstef
      Option is greyed out and I can't select it? Earlier in the process I did select z probe pin and modulation pin, but it won't let me select the option on the bottom of the endstop page?
      • T3P3Tonyundefined
        T3P3Tony administrators @clearlynotstef
        @clearlynotstef you should select a modulation pin (used to change the sensitivity on the smart effector) in the I/O Mapping page.
        www.duet3d.com
        clearlynotstefundefined 1 Reply Last reply Reply Quote 0
          clearlynotstef @T3P3Tony
          @t3p3tony I did (z probe.mod or something to that effect)
          • T3P3Tonyundefined
            @clearlynotstef ahh odd. I just tested it
            And with those defined it came up as an option.
            www.duet3d.com
              @t3p3tony I'll try over from scratch later, when I did the same thing and got to endstops it wouldn't select the smart effector. I also had problems on that page selecting "high" for the endstops at the top, when I refreshed twice then I was able to. We'll see how it goes from scratch.
