    Heater "pumping" when in standby
    Using Duet Controllers
    343
    • audryhomeundefined
      audryhome
      As shown in the picture, the yellow heater "pumps" when in standby, then goes back to normal as it activated again. No problem so far since I never saw an active heater pumping.
      Both heaters have been tuned with M303 then M500 stored parameters in config_override.g
        Can you give some more details?
        audryhomeundefined 1 Reply Last reply Reply Quote 0
          audryhome @Phaedrux
          @phaedrux Here is the config.g & config_override.g
          The heater that pumps is H2
          config.g
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Jan 07 2022 10:08:48 GMT+0100 (heure normale d’Europe centrale)
          M550 P"BigBox_Duet" ; set printer name
          M552 S1 P"XXXXX" ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S1 ; disable FTP
          M586 P2 S1 ; disable Telnet
          M569 P0 S0 ; physical drive 0 goes forwards
          M569 P1 S1 ; physical drive 1 goes backwards
          M569 P2 S1 ; physical drive 2 goes backwards
          M569 P3 S0 ; physical drive 3 goes forwards
          M569 P4 S0 ; physical drive 4 goes forwards
          M584 X0 Y1 Z2 E3:4 ; set drive mapping
          M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
          M92 X160.00 Y360.00 Z1600.00 E304.00:304.00 ; set steps per mm
          M566 X600.00 Y600.00 Z30.00 E20.00:20.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X8000.00 Y6000.00 Z360.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
          M906 X400 Y400 Z1200 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          ;M208 X0 Y0 Z0 S1 ; set axis minima
          M208 X0:330 Y0:240 Z0:300 S0 ; set axis maxima
          M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
          M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
          M574 Z1 S2
          ;M558 P5 C"zprobe.in" H5 F120 I1 T6000 ; set Z probe type to unmodulated and the dive height + speeds
          M558 P1 C"zprobe.in" I0 H5 R0.5 F340 T6000
          ;M558 P1 X0 Y0 Z1 H3 F200 T5000 ; Smart IR Z probe, used for homing Z axis, dive height 3mm, probe speed 200mm/min, travel speed 5000mm/min
          G31 X-60.0 Y0 Z1.6 P510 ; Set the probe height and threshold (put your own values here)
          M557 X10:275 Y5:195 S85 ; define mesh grid
          M106 P1 S1 H1 T50:60 ; set fan 1 value. Thermostatic control is turned on
          M106 P2 S1 H2 T50:60 ; set fan 2 value. Thermostatic control is turned on
          M308 S0 P"bed_temp" Y"thermistor" T100000 B4725 C7.06e-8 A"Bed" ; configure sensor 0 as thermistor on pin bedtemp Semitec 104 GT2 for AC Bed
          M950 H0 C"bedheat" T0 A"Bed" Q10 ; create bed heater output on bedheat and map it to sensor 0
          M140 H0 ;S80 R60 ; map heated bed to heater 0 , active 80°C, stdby 60°C
          M143 H0 S150 ; set temperature limit for heater 0 to 120C
          M308 S1 P"spi.cs2" Y"rtd-max31865" A"Direct" ; configure sensor 1 as PT100 on pin spi.cs1
          M570 H1 P5 T20 ; set heater fault detection parameter
          M308 S2 P"spi.cs1" Y"rtd-max31865" A"Bowden" ; configure sensor 2 as PT100 on pin spi.cs2
          M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
          M570 H2 P5 T20 ; set heater fault detection parameter
          M143 H2 S280 ; set temperature limit for heater 2 to 280C
          ;Tool0
          G10 P0 X0 Y0 ; set tool 0 axis offsets
          ; Tool1
          M563 P1 D1 H2 F0 ; define tool 1
          G10 P1 X-37.61 Y1.44 Z0 ; set tool 1 axis offsets
          G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
          ; read stored PID parameters
          M501
          config_ovverride.g
          ; config-override.g file generated in response to M500 at 2022-02-16 09:07
          ; Heater model parameters
          M307 H0 R0.935 K0.408:0.000 D2.93 E1.35 S1.00 B0
          M307 H1 R1.942 K0.445:0.129 D5.33 E1.00 S1.00 B0 V24.4
          M307 H2 R1.851 K0.261:0.199 D5.67 E1.35 S1.00 B0 V24.4
            So when you say that it pumps, you're referring to the up and down saw tooth pattern displayed in the gragh?
            What does the heater graph in DWC look like?
            What does the actual displayed temperature in DWC look like?
            Is this perhaps an artifact of using octoprint for monitoring?
            audryhomeundefined 2 Replies Last reply Reply Quote 0
              audryhome @Phaedrux
              @phaedrux I did not record the graph on DWC since I mainly use Octoprint as a GUI.
              I don't think it's an artefact from octoprint but I'll check next time it happens and let you know.
              let's see
                audryhome @Phaedrux
                @phaedrux
                Hi
                This is a copy of the screen
                The green one is the faulty guy
                  Firmware version?
                    dc42 administrators @audryhome
                    @audryhome if the temperature is oscillating, the usual fix is to increase the D parameter in the M307 command for the heater concerned. Try increasing it by 30%, and if that doesn't stop it, by 60%. You can send M307 with just the H and D parameters from the console while watching the temperature graph; then when you have established what value you need, edit the corresponding M307 command in config.g.
