    M556 axis compensation for a CNC
    CNC
    1.3k
    • Jrowundefined
      Jrow
      I put some tape on either motor coupler and ran Y homing from different start positions, very slowly and absolutely confirmed this working in action. I've now squared the CNC, by adjusting one of the sensors until my dial gauge read the same from one end of the linear rail to the other, when sliding it along a square. It's probably not perfect, but it should do for now, at least as proof to myself that I can do it this way.
      Notably, I also had to up my idle motor currents a little so it wouldn't go back out of square when they timed out. That's the I value on M906, where you set your motor amps.
      • sinned6915undefined
        sinned6915 @jay_s_uk
        @jay_s_uk what do we do if we only hve 1 axis motor?
        I got here searching for M556 as well. I set a piece of long stock in the machine and thought I had properly trammed it. I'm of about 0.3 in 200mm, I thought no biggie, I will just use the FW to skew corrrect instead of unclamping and realigning.
        Can we use M556 to tansform the coordiante system to account for crooked material or fixturing?
          jay_s_uk @sinned6915
          @sinned6915 if you're accounting for stock skew use G68 https://docs.duet3d.com/en/User_manual/Reference/Gcodes#g68-coordinate-rotation
