    DWC on mobile jumping/flickering due to Voltage fluctuations
    Duet Web Control
    • Schild0rundefined
      Schild0r
      Heyho,
      I got an issue with DWC on mobile where the whole page below the "sensors" info panel will jump up or down one line because with Vin at 24.1V the whole topic will fit into 3 lines but whenever Vin changes to 24.2 or 24.0 (0 and 2 are wider characters than 1) the last item (in my case z-probe) will be pushed into the nex line. Here is two screenshots side by side:
      With voltage fluctuations or the Vin sitting at about 24.15V this is quite annoying and leads to the page jumping multiple times a second which makes it hard to hit a certain button and not accidentally tap below or above it.
      I was wondering if I am the only one experiencing this and whether this is dependent on the screen resolution or if there would be a way to fix it...
      For me it would probably be enough to change the label "MCU Temperature" to "MCU Temp." but if this breaks things for other people with different screen resolutions that wouldn't be a proper fix.
        Which phone/browser and which version of DWC?
        Schild0rundefined 1 Reply Last reply Reply Quote 0
        • Schild0rundefined
          Schild0r @Phaedrux
          @phaedrux Oneplus 8 Pro (doesn't matter if I run it at FHD or 4k) on chrome and brave. DWC 3.3.0
