    co2 Laser fire duet 0.85
    Laser Cutters
    1.2k
    • Gaouundefined
      Gaou @Phaedrux
      @phaedrux
      if i send M452 p20 s1 the firmware says "bad p parameter"
      Delta Printer || Duet 0.85 || firmware 1.23
      Laser K40 || Duet 0.85 || Firmware 1.26.1 || Web 1.22
      • o_lampeundefined
        o_lampe @Gaou
        @gaou
        I've played with diode laser on older RRF versions, but never use M571 or M452. There was a plugin raster2gcode and others in inkscape, that allowed me to use M106 P0 Snnn to switch power on and M107 (or M106 P0 S0) to power off.
        What concernes me are the high currents you run your 40W? laser tube with. I'd never go above 12mA, better stay around 10mA for cutting.
        Gaouundefined 1 Reply Last reply Reply Quote 0
        • Gaouundefined
          Gaou @o_lampe
          @o_lampe said in co2 Laser fire duet 0.85:
          @gaou
          I keep that in mind but i would prefer to do this by the lightburn way....! I was thinking of writhing a macro and change the gcode on notepad++ .
          I knew that inkscape can write gcode for the lasers but because of my job i am very addicted to lightburn that comes with the big lasers. I am so addicted to duet also....! ANyway this is probably the way to go and thanks that bringing this up...
          I cant remember what exactly was the power range of this tube and it is the second i own ( sold the first) but during the tests i am using a test resistor that is intended for that job. it can stand up to 100w power ..
          Thanks a lot for replying.
            Phaedrux Moderator @Gaou
            @gaou said in co2 Laser fire duet 0.85:
            @phaedrux
            Sorry, I think I may have been looking at the wrong logical pin number section.
            Here's the one for the 0.85 board. Which of those listed pins are you using? Keep in mine, I have zero familiarity with the older pre-Duet2 boards.
            https://duet3d.dozuki.com/Wiki/Using_servos_and_controlling_unused_IO_pins#Section_Duet_0_6_and_0_8_Num_5
            • Gaouundefined
              Gaou @Phaedrux
              @phaedrux said in co2 Laser fire duet 0.85:
              @phaedrux
              i cant understand how are these connected to fan0 . all of these seems to be at the expansion header.
                Yes I'm not sure either. I'll check.
                  "bad p parameter"
                  So P20 is correct I think, but we may have missed the important step of freeing up the pin first by disabling the fan with M106 P0 I-1. So give that a try.
                  • Gaouundefined
                    Gaou @Phaedrux
                    "bad p parameter"
                    Look at my first post. I have already tried it and didn't get anything.
                      Sorry I missed that. I'll see if DC42 can take another look. From what I gather, it should be working.
                      If you send M452 by itself what does it respond with?
                      • Gaouundefined
                        Gaou @Phaedrux
                        @phaedrux
                        first of all thanks for ur insistense on my request.
                        there is no need for DC to step in the post. i think he has already too many things to care. I will qo on with the m106 command. It would do the job alright, it just would be safer for that kind of cnc ( laser beam) to act only on G1'sx.
                        if i send m450 i am getting a laser mode....
                        • Gaouundefined
                          Gaou @Gaou
                          i ve managed to get some results working a bit with lightburn. i also noticed ( i have read it already) that both lightburn and laserweb can connect to the duet3d . I didn't try to control the the machine through them . i am using the web interface at the moment.
                          a short video
                          the upper right one is the clearest one but it still needs some more tweaking.
                          i am using both of the pwm fans output to control the laser ( FAN0) and the exhaust fan (FAN1) and the workaround for the second fan is to replace the M8 M9 from Lightburn to M106 P1 S1 or S0
