    G29 S1 doesn't set move.compensation.meshDeviation.deviation
    • audryhome
      audryhome last edited by
      Since G29 S1 does load the heightmap.csv (by default) it should also set the corresponding values in the object model.
      I use these object model values to make a sanity check before launching a print, to avoid failures caused by an inconsistent bed level.
      There is no other mean to check heightmap.csv values, AFAIN there is no possibility to read these values using a meta command or classical gcode.
      Any idea?
        dc42 administrators @audryhome last edited by
        @audryhome thanks for reporting this. I have implemented a fix, which will be in 3.4.0RC2.
        audryhome 1 Reply Last reply Reply Quote 0
        • audryhome
          audryhome @dc42 last edited by
          @dc42 Many thanks David
