    Uploads not working
    Duet Web Control
    • vcapra1
      vcapra1 last edited by
      I sometimes can't get a file to upload to my printer over the network anymore. It will quickly get to like 10%, then get slower and slower until it almost stops (dropping to about 10 KiB/s and then apparently stopping). This is not a particularly large file, and there is plenty of space on the SD card.
      I've tried multiple resets without luck, but then suddenly it will start working again. This has happened a few times now, and it's beginning to get annoying because I usually don't realize the problem is back until I've spend 10 minutes heating everything up and homing the axes, only to have to power it down and remove the SD card to transfer files manually.
      It seems loosely tied to file size, as files less than 200KB will upload almost instantly, but anything above 500KB will start to drag on after 10-20% and eventually stop around 25%.
      Again, the issue isn't persistent, but usually lasts several hours. I've also tried things like rebooting my computer, my router, without any change. During these issues my computer can communicate with other devices on my network at or above gigabit speeds, so the issue is certainly isolated to the printer.
      M122:
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3beta3+1 (2021-04-28 21:24:54) running on Duet Ethernet 1.02 or later + DueX5
      Board ID: 08DGM-9T6BU-FG3SJ-6JTDJ-3SN6P-9SYZG
      Used output buffers: 4 of 24 (17 max)
      Static ram: 23876
      Dynamic ram: 73944 of which 0 recycled
      Never used RAM 16596, free system stack 118 words
      Tasks: NETWORK(ready,27.9%,205) HEAT(delaying,0.1%,330) Move(notifyWait,0.1%,303) DUEX(notifyWait,0.0%,24) MAIN(running,71.9%,278) IDLE(ready,0.1%,29), total 100.0%
      Owned mutexes:
      Last reset 00:09:06 ago, cause: power up
      Last software reset at 2022-02-14 16:12, reason: User, GCodes spinning, available RAM 16420, slot 1
      Error status: 0x00
      Aux0 errors 0,0,0
      Step timer max interval 0
      MCU temperature: min 24.7, current 36.2, max 36.7
      Supply voltage: min 24.2, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position -9800, standstill, SG min/max 0/266
      Driver 1: position 7000, standstill, SG min/max 0/243
      Driver 2: position 4386, standstill, SG min/max not available
      Driver 5: position 0, standstill, SG min/max 0/206
      Driver 6: position 0, standstill, SG min/max 0/111
      Driver 7: position 0, standstill, SG min/max 0/158
      Driver 8: position 0, standstill, SG min/max 0/167
      Driver 9: position 0, standstill, SG min/max 0/176
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2022-02-19 08:53:53
      Slowest loop: 81.25ms; fastest: 0.17ms
      === Storage ===
      Free file entries: 8
      SD card longest read time 3.7ms, write time 30.9ms, max retries 0
      DMs created 83, maxWait 238605ms, bed compensation in use: mesh, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 41, completed moves 41, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.1
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === DueX ===
      Read count 1, 0.11 reads/min
      === Network ===
      Slowest loop: 212.43ms; fastest: 0.02ms
      Responder states: HTTP(3) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
      HTTP sessions: 1 of 8
      Interface state active, link 100Mbps full duplex
      • droftarts
        droftarts administrators @vcapra1 last edited by
        @vcapra1 send M39 to check state of SD card, ie not so full that files are fragmented. You are also on a beta release of 3.3; update to the current 3.3 release. https://github.com/Duet3D/RepRapFirmware/releases/tag/3.3
        vcapra1 1 Reply Last reply Reply Quote 0
        • vcapra1
          vcapra1 @droftarts last edited by
          @droftarts Here's M39:
          SD card in slot 0: capacity 7.95Gb, free space 7.70Gb, speed 20.00MBytes/sec, cluster size 4kb
          I've upgraded to the 3.3 release, I'll post again here if the issue comes back
            Phaedrux Moderator @vcapra1 last edited by
            @vcapra1 said in Uploads not working:
            cluster size 4kb
            That seems like an odd cluster size. 32 or 64kb is recommended.
            I suggest you take the SD card out of the Duet and use your PC to back up the contents by copying the files. Then use the SD card formatter tool to wipe and format it. It will choose the most appropriate format based on the card.
            https://www.sdcard.org/downloads/formatter/
            Then copy the files back onto the card and test it out with M39 again and try and upload a file.
