    Pendant problems on Workbee with Duet2 wifi RR3
    CNC
    327
    • JvP79
      JvP79 last edited by JvP79
      Hi All!
      As my title says I hacve a workbee with a duet2 wifi board, which I recently upgraded to RR 3.3 firmware (dated 2021-06-15). Over the past week I build a pendant for it using Davids guide and firmware. The build went without issues, I've used an arduino micro pro clone which gave me some problems as the IDE software (1.8.1.9) did not see it on my USB C port. But using my wife's macbook I got it working and was able to upload the firmware to the board, which it seems to have succesfully done.
      I connected it to the duet2 paneldue port, and the led on the pendant nicely comes on and turns off when I hit the E-stop button on the pendant. But that is all it does.
      I mean there is no magic blue smoke or anything and the cnc performs as it should. Jet the cnc ignores any input from the pendant. No matter what I set the switches to, no input seems to reach the machine. It doesnt respond to the E-stop, or input from the rotating switch. The console remains blank as well.
      I checked the connections and all are correctly and there are no cable breaks or something as I can find. And as far as I know it is plug & play, so no changes/settings have to be made.
      Does anybody have a clue in which direction I should be looking to fix this and getting to work?
      Edit; just noticed that on the Duet2 board there are 2 panel due connections, one on the left (right next to Z probe) to which I connected the pendant. And the other one on the right of the board, which is labeled as Panel Due (Label:Conn_SD). Did I use the wrong port?
      • R4ffers
        R4ffers last edited by R4ffers
        Hi I'm not an expert at any stretch lol. I have this working on my Duet3 mb6hc. I have it wired in series with the paneldue, so have the paneldue support section in my .cfg. Maybe its something to do with that. Just a thought.
        Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Voron Switchwire, Duet 2 wifi on Ox CNC.
        • unrepentantgeek
          unrepentantgeek last edited by
          @jvp79 You want the port next to the z-probe. The other is for the SD card slot on the PanelDue.
          If the e-stop doesn't cause the Duet to e-stop then you don't have the communications line wired up right. Check those connections again.
          JvP79 1 Reply Last reply Reply Quote 0
          • JvP79
            JvP79 @unrepentantgeek last edited by
            @unrepentantgeek Thank you. That is what I thought, so the port is correct. I already checked the comm line but will do so again.
            • JvP79
              JvP79 @JvP79 last edited by
              I checked/measured the wiring again, as far as I can see it is correct. The TX1 is connected via a 6.8K Ohm resistor to the URXD and the GND is connected via a 10K Ohm resistor to the URXD on the same wire as well (black in my world, blue in the original plan).
              The only real difference I could find is that my pendant has 6 positions and I have connected the additional 2 (5 & 6) as well. Although this is in the plan as well, the colors of the wires differ, but that is it.
              Apologies for the quality of the pictures, it was the best I could get
              R4ffers 1 Reply Last reply Reply Quote 0
              • R4ffers
                R4ffers @JvP79 last edited by
                @jvp79 do you have this in your config? M575 P1 S1 B57600 for paneldue
                • JvP79
                  JvP79 @R4ffers last edited by
                  @r4ffersApologies for my late reply. Have been sick with the you know what virus.
                  I have not added that code to my config, I thought this pendant was plug and play. But I will check and see if that solves any issues.
                  dhusolo 1 Reply Last reply Reply Quote 1
                  • dhusolo
                    dhusolo @JvP79 last edited by
                    @jvp79 You need to add M575 P1 S1 B57600 or else the Duet doesn't know to send the serial communication over the serial port
                    • JvP79
                      Yess!! Adding that code to the config.g indeed did the trick! It works like a charm now!!
                      Thank you Raffers and Dhusolo for the suggestion!
