    Delta X0 Y0
    • Edkirk
      Edkirk last edited by
      Just finished my first DIY Delta and printing first print. I see the Delta "machine" X0 and Y0 is located in the center of the round bed and the slicer software, Simplify 3D, is also in the center of the bed. When the print starts it moves to the rear right of the bed to start printing at the edge of the print bed. I sort of solved the issue by entering a X-90 and Y-90 offset in S3D G Code. Is there a setting in config.h to compensate for the offset?
      Thanks, Ed
      • Edkirk
        I found the solution in S3D, I was in the correct area but going the wrong direction.
        Thanks, Ed
