    Help with start G-code for bed leveling.
    • westechundefined
      westech
      Newbee at this. I have had a BLTouch on my Ender 3 for awhile. Haven't really used it. I still have the Z endstop switch I'm using for homing. I guess I need to remove that?
      I use Cura. But I think this is the same for any "start G code."
      Someone was helping me on Discord about, manually executing a bed level mesh. Then storing that. Then only have the start g code retrieve the mesh. I do not want my G code to do a bed level at the start of each print.
      My goal was to be able to swap out my Mirror, for a textured flex plate. Do a manual bed level to compensate for the new bed height, and just print.
      So, I've read the info on G29 and M420.
      But I'd like to put that in practice if anyone could share their start G-code, as I mentioned that would just load the stored mesh.
      Let me se if I understand.
      I'd switch to say the flex bed. Run a bed level command. save that.
      Then in my Start G-code, I would Home X&Y, then use the BLTouch to home the Z, Then it would load the mesh data, then move on to printing?
      Thanks, just a little confused.
      Max
      • fcwiltundefined
        fcwilt @westech
        @westech
        In your mesh.g file, which is used to create the height map, you should have at least:
        ; *** THIS CODE ASSSUMES THE PRINTER IS ALREADY HOMED ***
        G29 S2                      ; cancel mesh bed compensation
        M290 R0 S0                  ; cancel baby stepping
        M557 Xaaa:bbb Yccc:ddd P20  ; define 400 point mesh (aaa, bbb, ccc, ddd need to be set suitable for your printer)
        G1 Xeee Yfff                ; move to center of bed (eee, fff  need to be set suitable for your printer)
        G30                         ; set Z=0 Datum
        G29 S0                      ; do probing and create heightmap.csv
        To load the height map you just need
        G30                         ; set Z=0 Datum
        G29 S1                      ; load heightmap.csv created with mesh.g
        westechundefined 1 Reply Last reply Reply Quote 0
        • westechundefined
          westech @fcwilt
          Thank you for the information. I'm trying to implement it.
          CURRENT MY START G-CODE:
          ; Ender 3 Custom Start G-code
          G92 E0 ; Reset Extruder
          G28 ; Home all axes
          G1 Z2.0 F3000 ; Move Z Axis up little
          G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
          G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
          G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
          G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
          G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish
          Does Mesh.g go in Sys or Marcos?
          Added the New Load Mesh to Start G code. (does this look correct?)
          G28 ; Home all axes
          G1 X110 Y110                ; move to center of bed
          G30                         ; set Z=0 Datum
          Also, I have one other issue I'm not sure about. For this to work, I need to remove my Z endstop switch?
          Thanks
          Max
          • fcwiltundefined
            fcwilt @westech
            @westech
            mesh.g goes into the SYS folder.
            All of my printers have a Z endstop sensor and a Z probe.
            I use the endstop sensor for homing and the probe for set the Z=0 Datum, bed leveling and mesh creation.
