    Home position corrupted on restart in 3.4rc1
    Beta Firmware
    • Gone2Farundefined
      Gone2Far
      Upgraded from 2.x this week. (What can I say, it was working for me. 🙂 ) Now seeing issue and error on restarting, happens both after restarting by changing config.g or by hitting emergency stop.
      Printer is a delta with ~325mm of vertical travel. Duet 2, Smart Effector.
      Restart applies the location set in the config at boot (X0Y0Z325), but then on homing it sets the coordinates to an odd value and then raises an error.
      Example:
      Printer is homed, coords x0y0z319.5
      G1Z50, coords X0Y0Z50
      Edit config.g (no changes), save and restart, coords x0y0z325
      G28, coords x-8.9y-1.0z621.1, error: G0/G1: target position not reachable from current position.
      I would expect homing to set the X and Y to 0 still, and the Z height to the configured calibrated height after homing.
      To recover, I have to:
      G92x0y0
      G30S-1
      G92Z0
      G28
      G32
      Tested with v3.3, same results.
      homedelta.g is the one generated by the configuration tool.
      ; homedelta.g
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Feb 16 2022 14:16:30 GMT-0800 (Pacific Standard Time)
      G91 ; relative positioning
      G1 H1 X355 Y355 Z355 F1800 ; move all towers to the high end stopping at the endstops (first pass)
      G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
      G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
      G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
      G90 ; absolute positioning
      G1 X0 Y0 F6000 ; move X+Y to the centre
      config.g:
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Feb 16 2022 14:16:29 GMT-0800 (Pacific Standard Time)
      M550 P"Kosselstein" ; set printer name
      M665 R235 L500.17 B145 H325 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M92 X160.00 Y160.00 Z160.00 E2600.00 ; set steps per mm
      M566 X600.00 Y600.00 Z600.00 E100.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X6000.00 Y6000.00 Z6000.00 E1500.00 ; set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1200 E850 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; set minimum Z
      M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
      M558 P5 R0.4 C"zprobe.in+zprobe.mod" H15 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
      M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
      G31 P100 X0 Y0 Z-0.21 ; set Z probe trigger value, offset and trigger height
      M557 R140 S20 ; define mesh grid
      M143 H0 S100 ; set temperature limit for heater 0 to 100C
      M106 P0 S0 H-1 L0.5 ; set fan 0 value. Thermostatic control is turned off, max 80%
      M950 F2 C"fan2" Q500
      M106 P2 S1 H1 T45
      M207 S2.0 R0.5 F1500 T900 Z0.5 ; Set FW retraction length and speed
      M572 D0 S0.10 ; Set pressure advance
      config-override.g:
      ; config-override.g file generated in response to M500 at 2022-02-21 11:36
      ; Delta parameters
      M665 L500.170:500.170:500.170 R239.169 H323.941 B145.0 X0.000 Y0.000 Z0.000
      M666 X-0.558 Y0.349 Z0.209 A0.00 B0.00
      ; Heater model parameters
      M307 H0 R0.158 K0.714:0.000 D3.22 E1.00 S1.00 B0
      M307 H1 R2.481 K0.714:0.000 D8.20 E1.00 S0.80 B0 V24.1
      ; Workplace coordinates
      G10 L2 P1 X0.00 Y0.00 Z0.00
      G10 L2 P2 X0.00 Y0.00 Z0.00
      G10 L2 P3 X0.00 Y0.00 Z0.00
      G10 L2 P4 X0.00 Y0.00 Z0.00
      G10 L2 P5 X0.00 Y0.00 Z0.00
      G10 L2 P6 X0.00 Y0.00 Z0.00
      G10 L2 P7 X0.00 Y0.00 Z0.00
      G10 L2 P8 X0.00 Y0.00 Z0.00
      G10 L2 P9 X0.00 Y0.00 Z0.00
      Original Prusa i3 MK2S
      Large Kossel Homebrew
        Phaedrux Moderator @Gone2Far
        @gone2far said in Home position corrupted on restart in 3.4rc1:
        Your endstop configuration is incorrect. They are set as low end endstops, but should be high end endstops. So when you run home delta it's setting the position to min instead of max.
        Change the X2 Y2 Z2 in those M574 commands.
        The configurator doesn't choose high end endstops by default for deltas, but it probably should since people often miss that.
        Gone2Farundefined 1 Reply Last reply Reply Quote 0
        • Gone2Farundefined
          Gone2Far @Phaedrux
          @phaedrux Thanks very much! Fixed.
