    Prusa heated bed settings for Duet2
    Using Duet Controllers
    • handyandy
      handyandy last edited by
      Does anyone know the settings I should use in the config tool for using a Prusa Mk52 24V heated bed with my duet2 controller?
      These are in the 'heaters' section of the config tool under...
      R25 - Heater thermister resistance
      B - Model coefficient
      C - Coefficient of the Steinhart-Hart equation!
      I am grateful for any help.
      Thank you.
      PetrKroupa 1 Reply Last reply Reply Quote 0
      • PetrKroupa
        PetrKroupa @handyandy last edited by PetrKroupa
        @handyandy -Here is my config.
        M308 S0 P"temp0" Y"thermistor" T100000 B4138             			; configure sensor 0 as thermistor on pin temp0
        M950 H0 C"out0"  Q10 T0                                  			; create bed heater output on out0 and map it to sensor 0     			; disable bang-bang mode, set PWM limit
        M307 H0 B0 R0.311 C426.5 D10.90 S1.00 V26.1
        M140 H0                                                  			; map heated bed to heater 0
        M143 H0 S120                                             			; set temperature limit for heater 0 to 120C
        BigOne:Duet3 6HC +1LC + Rpi4, mosquito hotend, 400x400x420
        SmallOne : Duet3 6HC +1LC + Rpi4, mosquito hotend, 210x250x210
        Petr
