    Height Map has a substantial Z offset
    My Duet controlled machine
    276
    • nicaris
      nicaris last edited by
      Help !
      I'm still having problems-this time concerning bed levellingScreenshot 2022-02-23 at 15-38-47 Nicks Ender +5+.png
      Unfortunately I have no idea what this means;
      Warning: the height map has a substantial Z offset
      I have repeatedly calibrated the Z height but nothing seems to make any difference .Needless to say I haven't managed to print anything yet.
      Thoughts anyone?
      N.Harris Duet2 Wifi on an Ender 5 Plus
      fcwilt 1 Reply Last reply Reply Quote 0
      • fcwilt
        fcwilt @nicaris last edited by
        @nicaris
        Based on the image I'm am guessing you are talking about Mesh Bed Compensation, not Bed Leveling.
        When creating or loading the heightmap you must first set the Z=0 Datum using G30.
        Something like this works fine:
        G1 Xaaa Ybbb ; where aaa and bbb will move the probe to the center of the bed on your printer
        G30 ; probe once and set the Z=0 Datum
        Now your heightmap is badly tilted but that is another issue.
        nicaris 2 Replies Last reply Reply Quote 0
        • nicaris
          nicaris @fcwilt last edited by
          @fcwilt Thanks for the swift reply and yes it was concerning mesh levelling (but I get the same error in bed levelling).
          I am new to this and have struggled ..why would the height map appear tilted when the bed definitely isn't ?
          • nicaris
            @fcwilt Thanks again that has removed the error after bed and mesh levelling but i still have that tilt.
            • fcwilt
              @nicaris said in Height Map has a substantial Z offset:
              Well the bed may not appear tilted but the heightmap says it is. But remember the heightmap is displaying small variations that may not be visible to the naked eye.
              Does your bed have any manual bed leveling adjustors?
              nicaris 1 Reply Last reply Reply Quote 0
              • nicaris
                @fcwilt Yes 4 ( 1in each corner)... how do i use them in reprap ?
                • fcwilt
                  Start with this:
                  Bed Leveling Assistant
                  If you cannot get it working let us know.
                  nicaris 1 Reply Last reply Reply Quote 1
                    It can help us if you share your config files and homing files etc so we can see what gcode is being run. That way we can spot errors and suggest specific changes.
                    • nicaris
                      @fcwilt Thanks again for your help- it will take some time to make the adjustments needed .
                      These are my Config Files :
                      ; original version generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Apr 10 2020 21:58:05 GMT-0600 (Mountain Daylight Time)
                      M550 P"Nick's Ender +5+ " ; set printer name
                      M552 S1
                      M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
                      M586 P0 S1 ; enable HTTP
                      M586 P1 S0 ; disable FTP
                      M586 P2 S0 ; disable Telnet
                      M569 P0 S0 ; physical drive 0 goes forewards
                      M569 P1 S0 ; physical drive 1 goes forewards
                      M569 P2 S1 ; physical drive 2 goes forewards
                      M569 P3 S1
                      M569 P4 S1 ; physical drive 3 goes forwards
                      M584 X0 Y1 Z2:4 E3 ; set drive mapping
                      ; Settings w/o interpolation - commented out
                      ;M350 X32 Y32 Z32 E128 I1 ; configure microstepping with interpolation
                      ;M92 X160.00 Y160.00 Z1600.00 E3533 ; set steps per mm
                      ;M566 X600.00 Y600.00 Z60.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)120
                      ;M203 X9000.00 Y9000.00 Z1200.00 E6000.00 ; set maximum speeds (mm/min)
                      ;M201 X3000.00 Y3000.00 Z60.00 E2500.00 ; set accelerations (mm/s^2)250
                      ; Settings w/ interpolation @ 16
                      M92 X80.00 Y80.00 Z800.00 E140 ; set steps per mm
                      M566 X600.00 Y600.00 Z30.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)300
                      M203 X9000.00 Y9000.00 Z500.00 E6000.00 ; set maximum speeds (mm/min)
                      M201 X800.00 Y800.00 Z250.00 E2500.00 ; set accelerations (mm/s^2)1500
                      M906 X600 Y600 Z600 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
                      M84 S30 ; Set idle timeout
                      M208 X0 Y6 Z0 S1 ; set axis minima
                      M208 X350 Y350 Z400 S0 ; set axis maxima
                      M574 Z0 ; disabled end stop for z c
                      M574 X1 S1 P"xstop" ; active low endstop for x-axis
                      M574 Y1 S1 P"ystop" ; active low endstop for y-axis
                      ; Filament Sensor
                      M591 D0 P1 S1 C"e0stop"
                      ; Based on https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Duet_2_WiFi_Ethernet_without_expansion_board
                      M307 H3 A-1 C-1 D-1
                      M280 P5 S10 I1 :c
                      M950 S0 C"exp.heater3" ; Set exp.heater3 (pin8 on expansion socket) as servo pin 0 for BLTouch c
                      M558 P9 C"^zprobe.in" H5 F120 T6000 A5 R0.1 X0 Y) Z1 ; set Z probe type to bltouch and the dive height + speeds c
                      G31 P500 X-28 Y-13 Z3.48 ; set Z probe trigger value, offset and trigger height c
                      M557 X0:300 Y0:300 S20 ; define mesh grid
                      M574 Z1 S2;c
                      M280 P5 S90 I1
                      ; Sensors
                      ; See https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names_for_Duet_2_WiFi_Ethernet
                      ; for pin names
                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; Bed Thermistor
                      ; I replaced my original e0temp thermistor, so if you have stock, use the same values as bed
                      M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; Extruder Thermistor
                      M950 H0 C"bedheat" T0 ; Create a heater using the bedheat output and the S0 temp sensor (bed heater)
                      M143 H0 S120 ; set temperature limit for heater 0 to 120CC0.0000000706
                      M140 H0 ; Set heater H0 as the bed heater
                      M950 H1 C"e0heat" T1 ; Create a heater using the e0heat output and the S1 temp sensor (extruder 0)
                      M143 H1 S290 ; set temperature limit for heater 1 to 290C
                      ; Bed adjustment screw locations
                      M671 X15:300:300:15 Y35:40:320:320 P0.7 ; mark leveling screws at (316,295) (316,35) (46,295) (46,35)
                      M950 F0 C"fan0" Q500 ; Set fan 0 to pin "fan0" with PWM freq 500 Hz
                      M106 P0 C"part-cooling" S0.65 H-1 ; set fan 0 name and fan speed to 65%. Thermostatic control is turned oncp0 h0
                      M950 F1 C"Fan1" Q500 ; Set fan 1 to pin "fan1" with PWM freq 500 Hz
                      M106 P1 C"hotend" S0.50 H1 T100 ; set fan 1 name and fan speed. Thermostatic control is turned off
                      M950 F2 C"fan2" Q500 ; Set fan 2 to pin "fan2" with PWM freq 500 Hz
                      M106 P2 S0.85 H-1 ; set fan 2 speed. Thermostatic control is turned off
                      M911 S12 R20 P"M913 X0 Y0 G91 M83 G1
                      ; bed.g
                      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Feb 17 2022 16:47:45 GMT+0000 (Greenwich Mean Time)
                      G29 ; probe the bed and enable compensation
                      G28 ; home
                      M401 ; deploy Z probe
                      G30 P0 X35 Y35 Z-99999 ; probe near an adjusting screw
                      G30 P1 X300 Y40 Z-99999 ; probe near an adjusting screw
                      G30 P2 X300 Y320 Z-99999 ; probe near an adjusting screw
                      G30 P3 X35 Y320 Z-99999 S4 ; 4th adj screw and report adjustments needed
                      M402 ; retract probe
                      ; homeall.g
                      ; called to home all axes
                      G91 ; relative positioning
                      G1 H1 X-355 Y-355 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                      G1 H1 X-355 ; home X axis
                      G1 H1 Y-355 ; home Y axis
                      G1 X5 Y5 F6000 ; go back a few mm
                      G1 H1 X-355 F360 ; move slowly to X axis endstop once more (second pass)
                      G1 H1 Y-355 ; then move slowly to Y axis endstop
                      G90 ; absolute positioning
                      G1 X15 Y15 F6000 ; go to first bed probe point and home Z
                      ;G91 ; relative positioning
                      ;G1 Z5 F100 ; lift Z relative to current position
                      ;G90 ; absolute positioning
                      Thanks again in advance -I think I'm going to need some help with retraction settings 🙂
                      fcwilt nicaris 2 Replies Last reply Reply Quote 0
                      • fcwilt
                        @nicaris
                        I understand that you are going to make some changes.
                        Let me point out that you are doing both height map creation and bed leveling in your bed.g file.
                        In v3 firmware (and later) the indented way to is to create the height map in a file called mesh.g and do bed leveling in bed.g.
                        With a BLTouch type probe you don't use the M401/M402 commands directly, they are invoked by the firmware as needed, so you can remove them.
                        • nicaris
                          nicaris @nicaris last edited by
                          @nicaris
                          So at the moment the height map is saved in heightmap.csv
                          I create a file called mesh.g for that ? and remove the m401 and m402 from bed.g
                          • fcwilt
                            @nicaris
                            The command G29 will run mesh.g.
                            The commands used to create the heightmap belong in mesh.g.
                            So mesh,g would be something like this:
                            ; *** THIS EXAMPLE ASSUMES THE PRINTER HAS BEEN HOMED - IT COULD INCLUDE HOMING IF DESIRED ***
                            M290 R0 S0                 ; cancel baby stepping
                            G1 Xaaa Ybbb               ; move probe to center of bed - change aaa, bbb as needed for your printer
                            G30                        ; set the Z=0 datum
                            M557 Xccc:ddd Yeee:fff P20 ; define 400 point mesh - change ccc, ddd, eee, fff as needed for your printer
                            G29 S0                     ; probe the bed and create the heightmap.csv file
