    Heater fault when moving Y Axis
    Using Duet Controllers
    • kmoore
      kmoore last edited by
      Hello, I could use some assistance. I am setting up a build using a DUET 3 HC6. I am installing a pellet extruder that is has three heaters with independent K-Style Thermocouples. I have the thermocouples ran to two daughterboards. I was able to get the heaters tuned but now when I move the Y axis my heaters fault and set to 2000 c instead of their actual temp.
      I checked the wiring on the thermocouples.
      I made sure the continuity is good.
      I disabled the Y Axis and moved the extruder by hand to see if it would trigger the heater fault (It did not).
      I've checked the wiring of my Y motor, everything is great.
      Thank you for your help
      below is the link to my config file.
      https://docs.google.com/document/d/10XdfVg8JJ72Q2h5y4btkh5xpThhucuYZW2Qnh01Lk8I/edit?usp=sharing
        Are you using thermocouple extension wires?
        Are they of the right type?
        Do the wires run next to any motor wiring?
        kmoore 2 Replies Last reply Reply Quote 0
        • kmoore
          kmoore @Phaedrux last edited by
          @phaedrux
          I am not. I am currently using 24ga wires. Did not know that thermocouple wires needed to be anything special.
          Ill try that next.
          Thank you
          • kmoore
            kmoore @Phaedrux last edited by kmoore
            This post is deleted!
