    Duet External USB drive
    • code7
      code7 last edited by
      Re: External SD Card or USB Slot in Duet 6 HC
      @dc42 Is the ability to add an external USB drive to the Duet something that may come out within the next month or is this FW addition further out?
      Delta Printer Using a Duet 2 Wifi v1.04c, FW3.4.0beta2, Duet WiFi sever 1.26, Duet Web Control 3.3.0
      Stephen6309 dc42 2 Replies Last reply Reply Quote 0
      • Stephen6309
        Stephen6309 @code7 last edited by
        @code7 The release notes for 3.4.0rc1 has [Duet 3 MB6HC in standalone mode] It is now possible to use the external SD card on an attached PanelDue, using a special wiring scheme
        https://docs.duet3d.com/en/User_manual/Connecting_hardware/Display_PanelDue has how in there.
          dc42 administrators @code7 last edited by
          @code7 as @Stephen6309 says, RRF 3.4.0 supports and external SD card (not USB drive) on the 6HC. If you run the 6HC with an attached Raspberry Pi then you can add USB storage to the Pi and print from it if you wish.
