UM2 Duet3D Wifi Conversion Z stop issue
  • Hi,
    I've installed the Duet3D wifi to my Ultimaker 2, and I am having trouble with the Z end stop. I issue the M119 command, and I get:
    M119
    Endstops - X: not stopped, Y: not stopped, Z: at max stop, Z probe: not stopped
    So the board is detecting the stop. However, my Z motor continues to hum and my homez.g script never advances to the next line.
    I have the Z stop switch at the bottom of my bed travel. I config the motors such that when I Machine Control (Z+10) the bed moves down. I am assuming when you mention lifting the head, it means to lower the bed.
    Would you help me modify my config.g file to home the Z axis?
    ================= Here is my config.g: =============
    M111 S0 ; Debugging off
    G21 ; Work in millimetres
    M208 X215 Y215 Z200 S0 ; Set axis maxima
    M574 X1 Y1 Z2 S0 ; Define active low and unused microswitches
    M569 P0 S0 ; Drive 0 goes backwards
    M569 P2 S0 ; Drive 2 goes forward
    M92 X80 Y80 Z400 E80 ; Set steps per mm
    M566 X900 Y900 Z500 E120 ; Set maximum instantaneous speed changes (mm/min)
    M203 X6000 Y6000 Z1000 E1200 ; Set maximum speeds (mm/min)
    M201 X500 Y500 Z350 E250 ; Set accelerations (mm/s^2)
    M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M143 S260 ; Set maximum heater temperature to 260C
    M305 P0 X200 ; Set thermistor + ADC parameters for heater 0 and remap it to channel 100
    M305 P1 X201 ; Set thermistor + ADC parameters for heater 1 and remap it to channel 101
    M563 P0 D0 H1 ; Define tool 0
    ============== Here is my homez.g: ==============
    ; Lift Z relatively to current position
    G91
    G1 Z5 F19000
    ; Back to absolute positioning
    G90
    ; Go to first bed probe point and home the Z axis
    G1 X15 Y15 F9000
    G30
    G91 ; relative mode
    G1 Z200 F9000 S1 ; move Z down until the switch triggers
    ; Go back a few mm
    G1 Z5 F9000
    G90
    ; Move slowly to Z axis endstop once more (second pass)
    G1 Z10 F360 S1
    G90 ; back to absolute mode
    G92 Z0.3 ; tell the firmware that we are at Z=0.3mm
    You have both a G30 bed probing command and a G1 S1 command in your Z homing file. I suggest you delete all of these lines from the start:
    G91
    G1 Z5 F19000
    G90
    G1 X15 Y15 F9000
    G30
    so that it starts with G91 followed by the G1 S1 Z200 command.
    When you have Z homing working by itself, put the same code in the Z homing section of homeall.h.
    HTH David
Locked
