Marlin inspired Configuration.h for Reprap Firmware
I have been following RRF for sometime and decided to take the plunge and had some difficulties converting from Marlin. In my research I stumbled across the GCode Meta commands wiki and thought this would be a great opportunity to learn something new.
I have started creating a Configuration.g which will allow for a user to simply port over values from Marlin and have a similar printing experience. Right now I am focusing on cartesian support with a bltouch to see if this project is feasible.
If anyone has ideas, resources or advice for debugging I would greatly appreciate it.
Repo: https://github.com/brewpirate/marlin-rrf/
Configuration.g
;=========================================================================== ;============================= Getting Started ============================= ;=========================================================================== global CUSTOM_MACHINE_NAME = "Ender 3" ;=========================================================================== ;============================= Thermal Settings ============================ ;=========================================================================== ; @see https://duet3d.dozuki.com/Wiki/M308 ; ; Options ; --------------------- ; thermistor ; pt1000 ; rtd-max31865 ; thermocouple-max31855 ; thermocouple-max31856 ; linear-analog ; dht21 ; dht22 ; dhthumidity ; current-loop-pyro ; drivers ; mcu-temp ; drivers-duex global TEMP_SENSOR_0 = "thermistor" global TEMP_SENSOR_BED = "thermistor" global HEATER_0_MAXTEMP = 275 global BED_MAXTEMP = 150 ; PID Hotend ; --------------------- ;global PIDTEMP = true ;global BANG_MAX 255 ;global PID_K1 0.95 ;global DEFAULT_Kp_LIST { 22.20, 22.20 } ;global DEFAULT_Ki_LIST { 1.08, 1.08 } ;global DEFAULT_Kd_LIST { 114.00, 114.00 } ; PID Bed Heating ; --------------------- ;global PIDTEMPBED ;global MAX_BED_POWER 255 ;global DEFAULT_bedKp 10.00 ;global DEFAULT_bedKi .023 ;global DEFAULT_bedKd 305.4 ;=========================================================================== ;============================== Endstop Settings =========================== ;=========================================================================== ; Specify here all the endstop connectors that are connected to any endstop or probe. ; Almost all printers will be using one per axis. Probes will use one or more of the ; extra connectors. Leave undefined any used for non-endstop and non-probe purposes. global USE_XMIN_PLUG = true global USE_YMIN_PLUG = true global USE_ZMIN_PLUG = true ;global USE_XMAX_PLUG = true ;global SE_YMAX_PLUG = true ;global USE_ZMAX_PLUG = true ; Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup). ;global X_MIN_ENDSTOP_INVERTING = true ; Set to true to invert the logic of the endstop. ;global Y_MIN_ENDSTOP_INVERTING = true ; Set to true to invert the logic of the endstop. ;global Z_MIN_ENDSTOP_INVERTING = true ; Set to true to invert the logic of the endstop. ;global X_MAX_ENDSTOP_INVERTING = true ; Set to true to invert the logic of the endstop. ;global Y_MAX_ENDSTOP_INVERTING = true ; Set to true to invert the logic of the endstop. ;global Z_MAX_ENDSTOP_INVERTING = true ; Set to true to invert the logic of the endstop. ;=========================================================================== ;============================= Mechanical Settings ========================= ;=========================================================================== ;============================================================================= ;============================== Movement Settings ============================ ;============================================================================= ;globalDEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 400, 500 } ;global DEFAULT_MAX_FEEDRATE { 300, 300, 5, 25 } ;global MAX_FEEDRATE_EDIT_VALUES { 600, 600, 10, 50 } ;global DEFAULT_MAX_ACCELERATION { 3000, 3000, 100, 10000 } ; X Axis ; --------------------- global X_MAX_CURRENT = 800 global X_MICROSTEPS = 16 global X_STEPS_PER_MM = 80.00 global X_MAX_SPEED = 9000.00 global X_MAX_SPEED_CHANGE = 1200.00 global X_ACCELERATION = 500.00 ;global INVERT_X_DIR = false ; Y Axis ; --------------------- global Y_MAX_CURRENT = 800 global Y_MICROSTEPS = 16 global Y_STEPS_PER_MM = 80.00 global Y_MAX_SPEED = 9000.00 global Y_MAX_SPEED_CHANGE = 1200.00 global Y_ACCELERATION = 500.00 ;global INVERT_Y_DIR = false ; Z Axis ; --------------------- global Z_MAX_CURRENT = 800 global Z_MICROSTEPS = 16 global Z_STEPS_PER_MM = 400.00 global Z_MAX_SPEED = 180.00 global Z_MAX_SPEED_CHANGE = 24.00 global Z_ACCELERATION = 100.00 ;global INVERT_Z_DIR = false ; Extruder ; --------------------- global E0_MAX_CURRENT = 800 global E0_MICROSTEPS = 16 global E0_STEPS_PER_MM = 93.00 global E0_MAX_SPEED = 6000.00 global E0_MAX_SPEED_CHANGE = 300.00 global E0_ACCELERATION = 5000.00 ;global INVERT_E0_DIR = false ; Jerk ; --------------------- ;global DEFAULT_XJERK 10.0 ;global DEFAULT_YJERK 10.0 ;global DEFAULT_ZJERK 0.3 ;=========================================================================== ;============================= Z Probe Options ============================= ;=========================================================================== ;/** ; * Probe Type ; * ; * Allen Key Probes, Servo Probes, Z-Sled Probes, FIX_MOUNTED_PROBE, etc. ; * Activate one of these to use Auto Bed Leveling below. ; */ ;** ; * The BLTouch probe uses a Hall effect sensor and emulates a servo. ; */ ;global BLTOUCH ;** ; * Nozzle-to-Probe offsets { X, Y, Z } ; * ; * X and Y offset ; * Use a caliper or ruler to measure the distance from the tip of ; * the Nozzle to the center-point of the Probe in the X and Y axes. ; * ; * Z offset ; * - For the Z offset use your best known value and adjust at runtime. ; * - Common probes trigger below the nozzle and have negative values for Z offset. ; * - Probes triggering above the nozzle height are uncommon but do exist. When using ; * probes such as this, carefully set Z_CLEARANCE_DEPLOY_PROBE and Z_CLEARANCE_BETWEEN_PROBES ; * to avoid collisions during probing. ; * ; * Tune and Adjust ; * - Probe Offsets can be tuned at runtime with 'M851', LCD menus, babystepping, etc. ; * - PROBE_OFFSET_WIZARD (configuration_adv.h) can be used for setting the Z offset. ; * ; * Assuming the typical work area orientation: ; * - Probe to RIGHT of the Nozzle has a Positive X offset ; * - Probe to LEFT of the Nozzle has a Negative X offset ; * - Probe in BACK of the Nozzle has a Positive Y offset ; * - Probe in FRONT of the Nozzle has a Negative Y offset ; * ; * ; * +-- BACK ---+ ; * | [+] | ; * L | 1 | R <-- Example "1" (right+, back+) ; * E | 2 | I <-- Example "2" ( left-, back+) ; * F |[-] N [+]| G <-- Nozzle ; * T | 3 | H <-- Example "3" (right+, front-) ; * | 4 | T <-- Example "4" ( left-, front-) ; * | [-] | ; * O-- FRONT --+ ; */ ;global NOZZLE_TO_PROBE_OFFSET { 10, 10, 0 } ; Most probes should stay away from the edges of the bed, but ; with NOZZLE_AS_PROBE this can be negative for a wider probing area. ;global PROBING_MARGIN 10 ; X and Y axis travel speed (mm/min) between probes ;global XY_PROBE_FEEDRATE (133*60) ; Feedrate (mm/min) for the first approach when double-probing (MULTIPLE_PROBING == 2) ;globalZ_PROBE_FEEDRATE_FAST (4*60) ; Feedrate (mm/min) for the "accurate" probe of each point ;global Z_PROBE_FEEDRATE_SLOW (Z_PROBE_FEEDRATE_FAST / 2) ; The size of the printable area global X_BED_SIZE = 235 global Y_BED_SIZE = 235 ; Travel limits (mm) after homing, corresponding to endstop positions. global X_MIN_POS = 0 global Y_MIN_POS = 0 global Z_MIN_POS = 0 global Z_MAX_POS = 260
config.g
; Configuration file for Duet Maestro (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Feb 23 2022 07:28:14 GMT-0800 (Pacific Standard Time) ; Load Configuration M98 P"Configuration.g" ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P{global.CUSTOM_MACHINE_NAME} ; set printer name ; Network M98 P"modules/network.g" ; Drives M98 P"modules/drives.g" ; Axis Limits M208 X{global.X_MIN_POS} Y{global.Y_MIN_POS} Z{global.Z_MIN_POS} S1 ; set axis minima M208 X{global.X_BED_SIZE} Y{global.Y_BED_SIZE} Z{global.Z_MAX_POS} S0 ; set axis maxima ; Endstops M98 P"modules/endstops.g" ; Z-Probe M98 P"modules/zprobe.g" ; Heaters M98 P"modules/thermal.g" ; Fans M98 P"modules/fans.g" ; Tools M98 P"modules/tools.g" ; Custom settings are not defined ; Miscellaneous M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
/sys/modules/endstops.g
; Declare base pin names for endstops var X_MIN_PIN_BASE = "xstop" var Y_MIN_PIN_BASE = "ystop" var Z_MIN_PIN_BASE = "zstop" var X_MAX_PIN_BASE = "xstop" var Y_MAX_PIN_BASE = "ystop" var Z_MAX_PIN_BASE = "zstop" ; X if exists(global.USE_XMIN_PLUG) var X_MIN_PIN = {exists(global.X_MIN_ENDSTOP_INVERTING) ? ("!" ^ var.X_MIN_PIN_BASE) : var.X_MIN_PIN_BASE} M574 X1 S1 P{var.X_MIN_PIN} if exists(global.USE_XMAX_PLUG) var X_MAX_PIN = {exists(global.X_MAX_ENDSTOP_INVERTING) ? ("!" ^ var.X_MAX_PIN_BASE) : var.X_MAX_PIN_BASE} M574 X2 S1 P{var.X_MAX_PIN} ; Y if exists(global.USE_YMIN_PLUG) var Y_MIN_PIN = {exists(global.Y_MIN_ENDSTOP_INVERTING) ? ("!" ^ var.Y_MIN_PIN_BASE) : var.Y_MIN_PIN_BASE} M574 Y1 S1 P{var.Y_MIN_PIN} if exists(global.USE_YMAX_PLUG) var Y_MAX_PIN = {exists(global.Y_MAX_ENDSTOP_INVERTING) ? ("!" ^ var.Y_MAX_PIN_BASE) : var.Y_MAX_PIN_BASE} M574 Y2 S1 P{var.Y_MAX_PIN} ; Z if exists(global.USE_ZMIN_PLUG) var Z_MIN_PIN = {exists(global.Z_MIN_ENDSTOP_INVERTING) ? ("!" ^ var.Z_MIN_PIN_BASE) : var.Z_MIN_PIN_BASE} M574 Z1 S1 P{var.Z_MIN_PIN} if exists(global.USE_ZMAX_PLUG) var Z_MAX_PIN = {exists(global.Z_MAX_ENDSTOP_INVERTING) ? ("!" ^ var.Z_MAX_PIN_BASE) : var.Z_MAX_PIN_BASE} M574 Z2 S1 P{var.Z_MAX_PIN}
Have you tested this on different boards? I ran into issues with using too many variables in the past and have since cut back ...
I have not tested many boards, I am very early into this project so I will have to keep that in mind. I was planning on having a machine type gcode
/sys/machine/cartesian.g
that would create all the global variables and then those values would be set with conditional Gcode. Would prevent creating unnecessary variables but without knowing what that limit is... guess I need to do some more research!I do not see a way to unset variables so I might have to be more strict with the use of local vs global variables. Hummm....
Since most of the global variables created in the configuration file.g are no longer needed after config.g runs, and if "too many globals" can become a problem as @oliof says, then this is a good use case for a way to "undeclare" a global variable and free up the memory. I could see an additional gcode file called from the end of config.g that would do the cleanup.
I would not use a limited and valuable resource like variables to hold constant values such as those needed for configuration.
Maybe it'd be better to have this static configuration file be processed and generating a normal config.g. If you want you can do this with metacommands/gcode, but it probably would be nicer to do it with some kind of web based configurator ... since most people find the Configuration.h and Configuration_adv.h unwieldy unless they've spent a lot of time with it (I am more comfortable with it than I'd like to admit).
I appreciate all the feedback, I have been thinking about this and going to scrap the idea and take a stab at a configuration plugin. The deeper I get the more problems I am seeing with using GCode and being a sr. frontend Vue developer I should be able to tackle this.
Stay tuned
