Solved Pressure advance example wrong
@t3p3tony The second example in the page about Pressure Advance (https://docs.duet3d.com/en/User_manual/Tuning/Pressure_advance) is wrong. It is not possible to have more than one S-value in a single M572-command.
My suggested replacement for this section is:
M572 D0 S0.1
The D parameter is the extruder drive number, and the S parameter is the amount of pressure advance you want for that extruder drive. If you have multiple extruders that should all have the same S value, you can specify them by listing their D values, separated by colons:
M572 D0:1 S0.1
To assign different values to different extruders, you need to use separate M572 commands.
@droftarts Ping!
This error in the documentation of Pressure Advance is still there.
/Ö
@örjane said in Pressure advance example wrong:
M572 D0 S0.1
M572 D0:1 S0.1
@örjane Thanks, finally updated!
droftarts
droftarts
