G32 on a delta is acting strange ..
I just upgraded my delta's firmware from 1.18 to 1.19. And as part of the calibration, I do a G32.
And it does probe the bed at the defined points, but between every one it goes to the far left corner, moves down a bit, then to the back of the bed where it does a sliding movement, before it continues to the next probe point.See a video of it here:
https://app.frame.io/f/rQmQHdCzWhy is that?!
Thank you in advance for any help
Kind regards, Niklas
Read the upgrade notes for going from 1.18 to 1.19, in particular the bit about the deployprobe.g and retractprobe.g files.
Oh thank you!
Important! If you use an IR Z probe or some other type that does not need to be deployed, delete the files sys/deployprobe and sys/retractprobe.g if they exist, because they are now called automatically. You can do this in the System Files Editor of the web interface.
