    Solved Duet 3 fails to start print
    Using Duet Controllers
    731
    • michaelr123
      michaelr123 last edited by
      Hi there,
      I just got in my replacement Duet 3 and got it re-installed with a raspberry PI SBC. Everything seems to be working properly, but when I try to run a print, it immediately states: M32 "0:/gcodes/Shape-Box-atlas.gcode"
      Error: M32: Cannot set file to print, because a file is already being printed
      DWC says its printing, but the system doesn't even begin to run the script. here's the M122 script:
      RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-9P63L-DJ3T8-6J1D4-3SD6R-9U479
      Used output buffers: 1 of 40 (12 max)
      Static ram: 150904
      Dynamic ram: 61780 of which 0 recycled
      Never used RAM 141508, free system stack 152 words
      Tasks: SBC(ready,15.8%,338) HEAT(delaying,0.0%,325) Move(notifyWait,0.0%,284) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,362) CanClock(notifyWait,0.0%,333) TMC(notifyWait,7.5%,59) MAIN(running,76.6%,1131) IDLE(ready,0.0%,29), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 00:04:23 ago, cause: software
      Last software reset at 2022-03-07 19:18, reason: User, GCodes spinning, available RAM 141724, slot 2
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
      Error status: 0x00
      Step timer max interval 197
      MCU temperature: min 48.8, current 49.1, max 49.2
      Supply voltage: min 23.7, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
      Driver 0: position 20000, standstill, reads 64071, writes 0 timeouts 0, SG min/max not available
      Driver 1: position 20000, standstill, reads 64071, writes 0 timeouts 0, SG min/max not available
      Driver 2: position 25600, standstill, reads 64070, writes 0 timeouts 0, SG min/max not available
      Driver 3: position 0, standstill, reads 64070, writes 0 timeouts 0, SG min/max not available
      Driver 4: position 0, standstill, reads 64070, writes 0 timeouts 0, SG min/max not available
      Driver 5: position 0, standstill, reads 64071, writes 0 timeouts 0, SG min/max not available
      Date/time: 2022-03-07 19:25:27
      Slowest loop: 6.99ms; fastest: 0.06ms
      === Storage ===
      Free file entries: 10
      === MainDDARing ===
      === AuxDDARing ===
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages queued 738, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 410/0/0
      Tx timeouts 0,0,410,0,0,328 last cancelled message type 4514 dest 127
      === SBC interface ===
      State: 4, failed transfers: 0, checksum errors: 0
      Last transfer: 2ms ago
      RX/TX seq numbers: 53132/53132
      SPI underruns 0, overruns 0
      Disconnects: 0, timeouts: 0, IAP RAM available 0x2c83c
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.4-rc2
      File /opt/dsf/sd/gcodes/Shape-Box-atlas.gcode is selected
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 1
      Full transfers per second: 3185.70, max time between full transfers: 13.0ms, max pin wait times: 11.5ms/11.2ms
      Codes per second: 0.02
      Maximum length of RX/TX data transfers: 3072/736
      3/7/2022, 7:25:21 PM M32 "0:/gcodes/Shape-Box-atlas.gcode"
      3/7/2022, 7:24:08 PM M122
      Used output buffers: 1 of 40 (10 max)
      Static ram: 150904
      Tasks: SBC(ready,15.0%,338) HEAT(delaying,0.0%,325) Move(notifyWait,0.0%,284) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,362) CanClock(notifyWait,0.0%,333) TMC(notifyWait,7.5%,59) MAIN(running,77.3%,1250) IDLE(ready,0.1%,29), total 100.0%
      Last reset 00:03:01 ago, cause: software
      Error status: 0x00
      Step timer max interval 189
      MCU temperature: min 48.7, current 49.0, max 49.2
      Driver 0: position 20000, standstill, reads 24387, writes 19 timeouts 0, SG min/max 0/262
      Driver 1: position 20000, standstill, reads 24387, writes 19 timeouts 0, SG min/max 0/453
      Driver 2: position 25600, standstill, reads 24387, writes 19 timeouts 0, SG min/max 0/335
      Driver 3: position 0, standstill, reads 24393, writes 14 timeouts 0, SG min/max 0/0
      Driver 4: position 0, standstill, reads 24396, writes 11 timeouts 0, SG min/max 0/0
      Driver 5: position 0, standstill, reads 24396, writes 11 timeouts 0, SG min/max 0/0
      Date/time: 2022-03-07 19:24:05
      Slowest loop: 31.27ms; fastest: 0.03ms
      === Storage ===
      DMs created 125, maxWait 80930ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 7, completed moves 7, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Heater 1 is on, I-accum = 0.1
      Segments left: 0
      === CAN ===
      Messages queued 1600, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 906/0/0
      Tx timeouts 0,2,905,0,0,690 last cancelled message type 4514 dest 127
      Last transfer: 1ms ago
      RX/TX seq numbers: 54099/54099
      Buffer RX/TX: 0/0-0
      Full transfers per second: 2885.78, max time between full transfers: 227.0ms, max pin wait times: 11.8ms/38.1ms
      Codes per second: 0.34
      Maximum length of RX/TX data transfers: 3028/736
      Any ideas?
      michaelr123 Phaedrux 2 Replies Last reply Reply Quote 0
      • michaelr123
        michaelr123 @michaelr123 last edited by michaelr123
        Also, when I hit pause, it runs the correct script, and says "Error: Attempting to extrude with no tool selected."
        Another weird thing, if I try to load the height map from the SD card it fails with: "Error: G29: Cannot use height map on local SD card when SBC interface is used" and while running a true bed leveling script, I get the following errors:
        3/7/2022, 7:49:00 PM Error: M307: Heater 1 not found
        3/7/2022, 7:49:00 PM Warning: SPI connection has been reset
        It looks like I'm having the same issue as before unfortunately...
        • Topic has been marked as a question  michaelr123 michaelr123
          Phaedrux Moderator @michaelr123 last edited by
          @michaelr123 said in Duet 3 fails to start print:
          Your Pi is running the release candidate for 3.4 but your Duet firmware is still on 3.3
          Which are you actually intending to use?
          Try sending M997 in the gcode console to prompt the Duet to update it's firmware. The 3.4 RC2 firmware bin is probably present, but just hasn't been applied.
          You can also try sending sudo apt update and sudo apt upgrade again in the pi terminal.
          Perhaps you were using 3.4 on your previous Duet+SBC but the new board is still using the last stable firmware.
          michaelr123 1 Reply Last reply Reply Quote 0
          • michaelr123
            michaelr123 @Phaedrux last edited by
            @phaedrux
            I tried to update the system once I installed it through the packet manager, it must not have fully taken across the whole system. I'm trying to move to 3.4 to start working on input shaping. I'll give that another shot tonight. I need to be able to at least start running a Gcode script to figure out the other problem.
            As for the system losing signal, I ordered some shielded cable to re-run the stepper wires. I was reading about how long stepper cables can sometimes cause problems on large systems. My other idea is to remove motors from the system and let them run on a bench to figure out what exactly is introducing the SPI reset problem. I'd appreciate any input from someone running a large format machine.
              I would say all your problems are from the firmware mismatch. Just send M997 and see what happens.
              • michaelr123
                @phaedrux
                You were correct on the M997 code, that got everything caught up and I was able to start a print and load the height map on the SD card which is all good, unfortunately I didn't make it very far into the print, here's the error code I got:
                3/8/2022, 6:39:02 PM M122
                RepRapFirmware for Duet 3 MB6HC version 3.4.0rc2 (2022-02-22 17:04:17) running on Duet 3 MB6HC v1.01 or later (SBC mode)
                Static ram: 150984
                Dynamic ram: 65544 of which 0 recycled
                Never used RAM 134144, free system stack 219 words
                Tasks: SBC(ready,0.5%,515) HEAT(notifyWait,0.0%,325) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,343) TMC(notifyWait,7.4%,92) MAIN(running,91.3%,1245) IDLE(ready,0.7%,30), total 100.0%
                Last reset 00:00:24 ago, cause: software
                Last software reset at 2022-03-08 18:38, reason: HardFault bfarValid precise, GCodes spinning, available RAM 133760, slot 2
                Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x0044a803 BFAR 0x40857f40 SP 0x2041b4f0 Task MAIN Freestk 1670 ok
                Stack: 00000000 40857e60 2041b594 00000000 fffffdc2 20429f28 0045c350 01000000 00000000 2042ba18 20419a7c 2042e1c4 00000000 00000001 00000000 004844d7 2042e1c4 00000000 00000000 0048481f 00000000 004849f7 a5a5a5a5 ffffffff a5a5a5a5 2042e1c4 ffffffff
                Error status: 0x00
                Step timer max interval 133
                MCU temperature: min 47.9, current 48.2, max 48.3
                Supply voltage: min 23.9, current 23.9, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                Events: 0 queued, 0 completed
                Driver 0: pos 0, standstill, SG min 0, mspos 600, reads 3924, writes 14 timeouts 0
                Driver 1: pos 0, standstill, SG min 0, mspos 152, reads 3924, writes 14 timeouts 0
                Driver 2: pos 0, standstill, SG min 0, mspos 460, reads 3924, writes 14 timeouts 0
                Driver 3: pos 0, standstill, SG min 0, mspos 596, reads 3925, writes 14 timeouts 0
                Driver 4: pos 0, standstill, SG min 0, mspos 8, reads 3928, writes 11 timeouts 0
                Driver 5: pos 0, standstill, SG min 0, mspos 8, reads 3928, writes 11 timeouts 0
                Date/time: 2022-03-08 18:39:01
                Slowest loop: 1.12ms; fastest: 0.04ms
                === Storage ===
                DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                === MainDDARing ===
                === AuxDDARing ===
                Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                Segments left: 0
                Code queue is empty
                === CAN ===
                Messages queued 215, received 0, lost 0, boc 0
                Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 121/0/0
                Tx timeouts 0,0,120,0,0,93 last cancelled message type 30 dest 127
                Transfer state: 4, failed transfers: 0, checksum errors: 0
                RX/TX seq numbers: 23656/962
                State: 5, disconnects: 0, timeouts: 0, IAP RAM available 0x2b8b0
                Buffer RX/TX: 0/0-0, open files: 0
                Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 17
                Full transfers per second: 39.60, max time between full transfers: 70.4ms, max pin wait times: 68.0ms/9.1ms
                Codes per second: 1.14
                Maximum length of RX/TX data transfers: 3352/1124
                3/8/2022, 6:38:39 PM Error: M307: Heater 1 not found
                3/8/2022, 6:38:38 PM Warning: SPI connection has been reset
                • michaelr123
                  @michaelr123
                  I think I figured it out, well partially. I started running a print with just one axis unplugged (manually pressed endstops, and yes, I turned off the system before I unplugged it).
                  I found that the Y axis wasn't the problem, but when I ran the print with the X axis, the print ran for a whole hour with no issues, other than the constant yellow warnings that driver 0.0 may be unplugged. I have a beautiful straight line blob to show for it!
                  So now I just need to figure out what about this stepper is causing the issue. The back case of the stepper is grounded already, any other ideas on where to ground the system? My other thought is the belt, or that the X axis isn't connected to the rest of the frame, its isolated by the plastic V-wheels. Maybe this is the issue?
                  Remember the system is a X-YY gantry with a moving Z platform.
                    Take a look through here: https://github.com/Duet3D/DuetSoftwareFramework/wiki/SBC-Setup-Guide#troubleshooting
                    Is this the error that happens consistently when the print fails?
                    • michaelr123
                      @phaedrux
                      Yes that's correct. The new thing I'm getting with 3.4 firmware is an M307 error "heater 1 not found" in addition to the spi reset error. This is what the system reports in DWC after the board resets:
                      I hope I got my point across in the last one, but the print ran successfully with the X-axis stepper unplugged. So the entire system ran happily for over an hour without the X-axis stepper running. I'll try using a shielded cable to run the signal to that stepper and see if that helps. I may also need to ground the suspended X-axis and belt system as this could potentially be generating problems?
                        Phaedrux Moderator @michaelr123 last edited by Phaedrux
                        Can you post your config.g and config-override.g? And the results of sending M98 P"config.g"?
                        • michaelr123
                          michaelr123 @Phaedrux last edited by michaelr123
                          @phaedrux
                          config (1).g
                          running M98:
                          3/9/2022, 8:56:02 PM M98 P"config.g"
                          3/9/2022, 8:56:02 PM Warning: M307: Heater 1 predicted maximum temperature at full power is 678°C
                          I don't have a config-override at the moment actually, that's strange.
                            M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin temp0
                            M950 H0 C"out0" T0                                    ; create bed heater output on out0 and map it to sensor 0
                             M307 H1 B0 R1.388 C470.8:420.6 D8.03 S1.00 V23.8     ; enable bang-bang mode for the bed heater and set PWM limit PID auto tuned on 3/7/2022
                            M140 H0                                               ; map heated bed to heater 0
                            M143 H0 S60                                           ; set temperature limit for heater 0 to 60C
                            M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
                            M950 H1 C"out1" T1                                    ; create nozzle heater output on out1 and map it to sensor 1
                            M307 H1 R1.222 K0.253:0.000 D12.18 E1.35 S1.00 B0 V23.8
                            M143 H1 S300
                            You have M307 H1 for both heaters.
                            I suggest you delete both of those M307 lines and then retune the heaters. This time use M500 to save the results to config-override.g and then add M501 to the end of config.g to load those settings at startup.
                            • michaelr123
                              @phaedrux
                              done:
                              config-override.g
                              config.g
                                Has that made any difference to the errors you're getting?
                                M307 H0 R0.130 K0.150:0.000 D10.00 E1.35 S1.00 B1
                                M307 H1 R1.374 K0.164:0.000 D8.22 E1.35 S1.00 B0 V23.8
                                Also, can you share the logs from the SBC after an error has occurred?
                                access the service logs from this particular unit by running journalctl -u duetcontrolserver -e. This will output the latest logs
                                • michaelr123
                                  @phaedrux
                                  I ran a print and it went for about 15 minutes before faulting out, here's the log:
                                  3/10/2022, 12:08:35 PM m122
                                  Static ram: 150984
                                  Dynamic ram: 65760 of which 0 recycled
                                  Never used RAM 133928, free system stack 219 words
                                  Tasks: SBC(ready,0.5%,494) HEAT(notifyWait,0.0%,327) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.4%,92) MAIN(running,90.7%,1245) IDLE(ready,1.4%,30), total 100.0%
                                  Last reset 00:00:17 ago, cause: software
                                  Last software reset at 2022-03-10 11:49, reason: HardFault undefInstr, GCodes spinning, available RAM 133784, slot 2
                                  Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00010000 ICSR 0x00427803 BFAR 0x00000000 SP 0x2041b500 Task MAIN Freestk 1674 ok
                                  Stack: 00000004 20432748 0000002c 00000144 00000002 00408d01 00408d48 010f0000 00000000 00000001 00000000 004844d7 2042bf34 00000000 00000000 0048481f 00000000 004849f7 2042c2d8 20429f28 00000000 2041b594 a5a5a5a5 0045c6ef ffffffff 00000000 2042c2d8
                                  Error status: 0x00
                                  MCU temperature: min 49.8, current 50.0, max 50.1
                                  Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                                  Driver 0: pos 0, standstill, SG min 0, mspos 1016, reads 34398, writes 14 timeouts 0
                                  Driver 1: pos 0, standstill, SG min 0, mspos 744, reads 34398, writes 14 timeouts 0
                                  Driver 2: pos 0, standstill, SG min 0, mspos 204, reads 34398, writes 14 timeouts 0
                                  Driver 3: pos 0, standstill, SG min 0, mspos 588, reads 34399, writes 14 timeouts 0
                                  Driver 4: pos 0, standstill, SG min 0, mspos 8, reads 34402, writes 11 timeouts 0
                                  Driver 5: pos 0, standstill, SG min 0, mspos 8, reads 34402, writes 11 timeouts 0
                                  Date/time: 2022-03-10 12:08:34
                                  Slowest loop: 1.08ms; fastest: 0.03ms
                                  === Storage ===
                                  === MainDDARing ===
                                  === AuxDDARing ===
                                  Segments left: 0
                                  Code queue is empty
                                  === CAN ===
                                  Messages queued 159, received 0, lost 0, boc 0
                                  Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 90/0/0
                                  Tx timeouts 0,0,89,0,0,68 last cancelled message type 30 dest 127
                                  RX/TX seq numbers: 45652/727
                                  Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 70
                                  Full transfers per second: 20.28, max time between full transfers: 654.7ms, max pin wait times: 76.3ms/10.6ms
                                  Codes per second: 0.61
                                  Maximum length of RX/TX data transfers: 5824/1100
                                  3/10/2022, 12:08:18 PM Warning: M307: Heater 1 predicted maximum temperature at full power is 507°C
                                  3/10/2022, 12:08:18 PM Warning: M307: Heater 0 predicted maximum temperature at full power is 114°C
                                  3/10/2022, 12:08:17 PM Warning: SPI connection has been reset
                                  3/10/2022, 12:08:17 PM Connection to Duet established
                                  3/10/2022, 12:08:17 PM Warning: Lost connection to Duet (Board is not available (no header))
                                    Phaedrux Moderator @Phaedrux last edited by
                                    @phaedrux said in Duet 3 fails to start print:
                                    Were you able to gather this?
                                    • michaelr123
                                      @phaedrux
                                      yes here it is, had to login to the pi and send this. It looks like there is a line about the spi connection right before the system spits out some info about the heaters. Maybe that is a result of the config override having M307 code in it and its just reporting some info on the H0 and H1 heaters. The other interesting thing is that I didn't add or tune H0. H0 is so that I can have a thermistor on the bed which is an AC heater. I just create the channel so I can monitor it. At the moment I just let it heat to max temperature (around 45C) without any PWM or bang-bang control going to the SSR.
                                      Mar 10 12:09:25 Duet3 DuetControlServer[447]: [info] Environment initialized
                                      Mar 10 12:09:25 Duet3 DuetControlServer[447]: [info] Connection to Duet establis
                                      Mar 10 12:09:25 Duet3 DuetControlServer[447]: [info] IPC socket created at /run/
                                      Mar 10 12:09:25 Duet3 systemd[1]: Started Duet Control Server.
                                      Mar 10 12:09:26 Duet3 DuetControlServer[447]: [info] Starting macro file config.
                                      Mar 10 12:09:28 Duet3 DuetControlServer[447]: [error] Failed to open 0:/sys/fila
                                      Mar 10 12:09:28 Duet3 DuetControlServer[447]: System.IO.FileNotFoundException
                                      Mar 10 12:09:28 Duet3 DuetControlServer[447]: File name: '/opt/dsf/sd/sys/filame
                                      Mar 10 12:09:28 Duet3 DuetControlServer[447]: at Microsoft.Win32.SafeHandles.
                                      Mar 10 12:09:28 Duet3 DuetControlServer[447]: at System.IO.Strategies.OSFileS
                                      Mar 10 12:09:28 Duet3 DuetControlServer[447]: at System.IO.Strategies.FileStr
                                      Mar 10 12:09:28 Duet3 DuetControlServer[447]: at System.IO.FileStream..ctor(S
                                      Mar 10 12:09:28 Duet3 DuetControlServer[447]: at DuetControlServer.SPI.Interf
                                      Mar 10 12:09:29 Duet3 DuetControlServer[447]: [info] Starting macro file config-
                                      Mar 10 12:09:29 Duet3 DuetControlServer[447]: [warn] M307: Heater 0 predicted ma
                                      Mar 10 12:09:29 Duet3 DuetControlServer[447]: [warn] M307: Heater 1 predicted ma
                                      Mar 10 12:09:29 Duet3 DuetControlServer[447]: [info] Finished macro file config-
                                      Mar 10 12:09:29 Duet3 DuetControlServer[447]: [info] Starting macro file tpre0.g
                                      Mar 10 12:09:29 Duet3 DuetControlServer[447]: [info] Finished macro file tpre0.g
                                      Mar 10 12:09:29 Duet3 DuetControlServer[447]: [info] Starting macro file tpost0.
                                      Mar 10 12:09:29 Duet3 DuetControlServer[447]: [info] Finished macro file tpost0.
                                      Mar 10 12:09:29 Duet3 DuetControlServer[447]: [info] Finished macro file config.
                                      lines 7-29/29 (END)
                                      Mar 10 12:09:25 Duet3 DuetControlServer[447]: [info] Connection to Duet established
                                      Mar 10 12:09:25 Duet3 DuetControlServer[447]: [info] IPC socket created at /run/dsf/dcs.sock
                                      Mar 10 12:09:26 Duet3 DuetControlServer[447]: [info] Starting macro file config.g on channel Trigger
                                      Mar 10 12:09:28 Duet3 DuetControlServer[447]: [error] Failed to open 0:/sys/filaments.csv for reading
                                      Mar 10 12:09:28 Duet3 DuetControlServer[447]: System.IO.FileNotFoundException: Could not find file '/opt/dsf/sd/sys/filaments.csv'.
                                      Mar 10 12:09:28 Duet3 DuetControlServer[447]: File name: '/opt/dsf/sd/sys/filaments.csv'
                                      Mar 10 12:09:28 Duet3 DuetControlServer[447]: at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode)
                                      Mar 10 12:09:28 Duet3 DuetControlServer[447]: at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String fullPath, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize)
                                      Mar 10 12:09:28 Duet3 DuetControlServer[447]: at System.IO.Strategies.OSFileStreamStrategy..ctor(String path, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize)
                                      Mar 10 12:09:28 Duet3 DuetControlServer[447]: at System.IO.Strategies.FileStreamHelpers.ChooseStrategy(FileStream fileStream, String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, Int64
                                      Mar 10 12:09:28 Duet3 DuetControlServer[447]: at System.IO.FileStream..ctor(String path, FileMode mode)
                                      Mar 10 12:09:28 Duet3 DuetControlServer[447]: at DuetControlServer.SPI.Interface.HandleOpenFile() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 1434
                                      Mar 10 12:09:29 Duet3 DuetControlServer[447]: [info] Starting macro file config-override.g on channel Trigger
                                      Mar 10 12:09:29 Duet3 DuetControlServer[447]: [warn] M307: Heater 0 predicted maximum temperature at full power is 114°C
                                      Mar 10 12:09:29 Duet3 DuetControlServer[447]: [warn] M307: Heater 1 predicted maximum temperature at full power is 507°C
                                      Mar 10 12:09:29 Duet3 DuetControlServer[447]: [info] Finished macro file config-override.g
                                      Mar 10 12:09:29 Duet3 DuetControlServer[447]: [info] Starting macro file tpre0.g on channel Trigger
                                      Mar 10 12:09:29 Duet3 DuetControlServer[447]: [info] Starting macro file tpost0.g on channel Trigger
                                      Mar 10 12:09:29 Duet3 DuetControlServer[447]: [info] Finished macro file tpost0.g
                                      Mar 10 12:09:29 Duet3 DuetControlServer[447]: [info] Finished macro file config.g
                                        Can you perform this loop back test?
                                        https://github.com/Duet3D/DuetSoftwareFramework/wiki/SBC-Setup-Guide#check-spi-data-lines-in-loopback-mode
                                        • michaelr123
                                          @phaedrux
                                          herer are the results from running the 3 script line. only difference I see is the SPI mode, is that something that should be fixed?
                                          spi mode: 4
                                          bits per word: 8
                                          max speed: 500000 Hz (500 KHz)
                                          FF FF FF FF FF FF
                                          40 00 00 00 00 95
                                          FF FF FF FF FF FF
                                          FF FF FF FF FF FF
                                          FF FF FF FF FF FF
                                          DE AD BE EF BA AD
                                          F0 0D
                                            spi mode: 4
                                            I'm not sure. I'll have to check.
                                            Do you happen to have another Pi to test with?
                                            • michaelr123
                                              @phaedrux
                                              I have a raspberry Pi 4 that I've tried with this system before and had the same issue as before unfortunately.
                                              I can run the same check and see what it says though,
                                                The other thing I would try is a fresh download and image of DuetPi.
                                                • michaelr123
                                                  @phaedrux
                                                  So here's what I've done so far:
                                                  -Fresh install of duetPi on my raspberry PI 4, re-ran RRF configurator with the latest settings to get a clean config file set going.
                                                  -shielded cable install on X-axis stepper driver and for Z-probe
                                                  -moved x-axis stepper driver to output 0.4 to see if it was something up with the 0.0 drive
                                                  Here's where I'm at:
                                                  I think I still am seeing the issue, but now I've seen it happen in an additional instance, I used the thermostatic cooler option for my coldside fan on my hemera which I kind of like, but then I accidently turned this on when I meant to turn on the part cooling fan, and this instantly gave me the same error that I've seen before, but for a different reason now. The M122 is listed below.
                                                  Other thought I had, is there any chance my ribbon cable is bad? Would that being faulty cause this type of issue?
                                                  M122
                                                  Used output buffers: 1 of 40 (14 max)
                                                  Static ram: 150984
                                                  Dynamic ram: 65804 of which 0 recycled
                                                  Never used RAM 133884, free system stack 219 words
                                                  Tasks: SBC(resourceWait:,0.5%,506) HEAT(notifyWait,0.0%,353) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,343) TMC(notifyWait,7.3%,92) MAIN(running,91.2%,1245) IDLE(ready,0.9%,30), total 100.0%
                                                  Last reset 00:00:18 ago, cause: software
                                                  Last software reset at 2022-03-14 16:06, reason: AssertionFailed, GCodes spinning, available RAM 133376, slot 0
                                                  Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x2041b504 Task MAIN Freestk 1675 ok
                                                  Stack: 00001014 004a3b10 00485807 00000000 2042ba18 20419a7c 2042d6e4 00000000 00000001 00000000 004844d7 2042d6e4 00000000 00000000 0048480f 00000000 00000000 20429860 2042d6e0 00000000 2042d6e4 20419a7c 00000000 55700d65 a5a5a5a5 a5a5a5a5 0048493b
                                                  Error status: 0x00
                                                  Step timer max interval 134
                                                  MCU temperature: min 50.6, current 50.9, max 50.9
                                                  Driver 0: pos 0, standstill, SG min 0, mspos 8, reads 39308, writes 11 timeouts 0
                                                  Driver 1: pos 0, standstill, SG min 0, mspos 40, reads 39305, writes 14 timeouts 0
                                                  Driver 2: pos 0, standstill, SG min 0, mspos 40, reads 39305, writes 14 timeouts 0
                                                  Driver 3: pos 0, standstill, SG min 0, mspos 888, reads 39305, writes 14 timeouts 0
                                                  Driver 4: pos 0, standstill, SG min 0, mspos 232, reads 39305, writes 14 timeouts 0
                                                  Driver 5: pos 0, standstill, SG min 0, mspos 8, reads 39308, writes 11 timeouts 0
                                                  Date/time: 2022-03-14 16:06:19
                                                  Slowest loop: 1.09ms; fastest: 0.05ms
                                                  === Storage ===
                                                  === MainDDARing ===
                                                  === AuxDDARing ===
                                                  Segments left: 0
                                                  Code queue is empty
                                                  === CAN ===
                                                  Messages queued 168, received 0, lost 0, boc 0
                                                  Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 95/0/0
                                                  Tx timeouts 0,0,94,0,0,72 last cancelled message type 30 dest 127
                                                  RX/TX seq numbers: 11267/750
                                                  Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 45
                                                  Full transfers per second: 39.82, max time between full transfers: 131.9ms, max pin wait times: 57.0ms/3.3ms
                                                  Codes per second: 2.85
                                                  Maximum length of RX/TX data transfers: 3404/1664
                                                  3/14/2022, 4:06:02 PM Warning: M307: Heater 0 predicted maximum temperature at full power is 321°C
                                                  3/14/2022, 4:06:02 PM Warning: SPI connection has been reset
                                                  config (2).g
                                                  • michaelr123
                                                    And here's one after running for a few minutes on a print:
                                                    M122
                                                    Static ram: 150984
                                                    Tasks: SBC(resourceWait:,0.6%,482) HEAT(notifyWait,0.0%,359) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,343) TMC(notifyWait,7.3%,92) MAIN(running,90.6%,1245) IDLE(ready,1.5%,30), total 100.0%
                                                    Last reset 00:00:11 ago, cause: software
                                                    Last software reset at 2022-03-14 16:19, reason: MemoryProtectionFault mmarValid daccViol, GCodes spinning, available RAM 133668, slot 1
                                                    Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x0044a804 BFAR 0xa5a5a5a6 SP 0x2041b520 Task MAIN Freestk 1682 ok
                                                    Stack: a5a5a5a5 2042b570 00000001 2042406c 00000002 0045c81b 00418cba 21000000 2042b400 00457c1b 2042b510 ffffff00 2042b570 20429f28 00000000 0045c6ef ffffffff 00000000 23d66c2b 00484b0f 2042b570 20429f28 00000000 23d66c2b a5a5a5a5 0045c81b 2042a980
                                                    Error status: 0x00
                                                    Step timer max interval 141
                                                    MCU temperature: min 50.7, current 50.9, max 51.0
                                                    12V rail voltage: min 12.1, current 12.1, max 12.1, under voltage events: 0
                                                    Driver 0: pos 0, standstill, SG min 0, mspos 8, reads 313, writes 11 timeouts 0
                                                    Driver 1: pos 0, standstill, SG min 0, mspos 840, reads 310, writes 14 timeouts 0
                                                    Driver 2: pos 0, standstill, SG min 0, mspos 8, reads 310, writes 14 timeouts 0
                                                    Driver 3: pos 0, standstill, SG min 0, mspos 648, reads 310, writes 14 timeouts 0
                                                    Driver 4: pos 0, standstill, SG min 0, mspos 184, reads 311, writes 14 timeouts 0
                                                    Driver 5: pos 0, standstill, SG min 0, mspos 8, reads 314, writes 11 timeouts 0
                                                    Date/time: 2022-03-14 16:19:33
                                                    === Storage ===
                                                    === MainDDARing ===
                                                    === AuxDDARing ===
                                                    Segments left: 0
                                                    Code queue is empty
                                                    === CAN ===
                                                    Messages queued 105, received 0, lost 0, boc 0
                                                    Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 60/0/0
                                                    Tx timeouts 0,0,59,0,0,44 last cancelled message type 30 dest 127
                                                    RX/TX seq numbers: 42465/476
                                                    Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 71
                                                    Full transfers per second: 39.25, max time between full transfers: 66.1ms, max pin wait times: 59.8ms/7.0ms
                                                    Codes per second: 5.65
                                                    Maximum length of RX/TX data transfers: 3472/1664
                                                      Was the loop back test the same result with the new Pi?
                                                      The ribbon could be bad, but would be unusual. You could make a small jumper cable harness to test instead of the ribbon cable.
                                                      Can you post some photos of your setup? Are there cables running close together in a drag chain or bundle?
