    Tool not picking up
    • A Former User?
      A Former User
      hey community
      I rebuild my printer and now after some setting changes the tool isn´t picked up by the coupler when activated. Also it´s possible now to activate 2 tools at the same time.
      May somebody can check my g.code or give me a link to an good explanation. thanks a lot to this community
      cheers
      EDIT:
      When Ì start printing the tool is piked p by the coupler as usual.
      Also I have to set my pick up coordinates in combination with my offset which is not the deal.
      R.G.```
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Aug 02 2021 16:15:35 GMT+0200 (Mitteleuropäische Sommerzeit)
      M550 P"Duet 3" ; set printer name
      M552 s1
      M587 S"AndroidAPebc3_EXT" P"hhhhhhhh"
      G4 S4
      M574 C1 S3
      M574 C0 Z0
      M915 P0.5 C S0 F0 R1
      ; Drives ;closed loop
      M569.1 P20.0 T2 C5 R69 I0 D0.06 H10 ; Configure the 1HCL board at CAN address.20quadrature encoder 128 steps/motor full
      M569.1 P21.0 T2 C5 R69 I0 D0.06 H10 ; Configure the 1HCL board at CAN address.21quadrature encoder 128 steps/motor full step.
      M569.1 P22.0 T2 C5 R100 I0 D0 H10 ; Configure the 1HCL board at CAN address.21quadrature encoder 128 steps/motor full step.
      M569 P20.0 D4 S1 ; Configure the motor on the 1HCL at can address 20 as being in closed-loop drive mode (D4) and not reversed (S1)
      M569 P21.0 D4 S0 ; Configure the motor on the 1HCL at can address 21 as being in closed-loop drive mode (D4) and not reversed (S1)
      M569 P22.0 D4 S1 ; Configure the motor on the 1HCL at can address 21 as being in closed-loop drive mode (D4) and not reversed (S1)
      Other drives; open loop;
      M569 P0.1 S1 ; physical drive 0.2 goes forwards
      M569 P0.2 S1 ; physical drive 0.2 goes forwards
      M569 P0.3 S1
      M569 P0.5 S0
      M569 P100.0 S0 ; physical drive 0.2 goes forwards
      M569 P101.0 S0 ; physical drive 0.2 goes forwards
      M584 X22.0 Y20.0:21.0 Z0.0:0.1:0.2:0.3 C0.5 E100.0:101.0 ; set drive mapping
      M350 X32 Y32 Z128 E16:16:16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z5120.00 C91.022 E409.00:409.00:409.00 ; set steps per mm
      M566 X600.00 Y600.00 Z60.00 C3000 E600.00:600.00:600.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X8000.00 Y8000.00 Z500.00 C10000 E6000.00:6000.00:6000.00 ; set maximum speeds (mm/min)
      M201 X1600.00 Y1600.00 Z500.00 C400 E2500.00:2500.00 ; set accelerations (mm/s^2)
      M906 X1700 Y1700:1700 Z2300:2300:2300:2300 C400 E1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S300 ; Set idle timeout
      M671 X-110:-110:1140:1140 Y-100:1140:1140:-110 S20 ; leadscrews at front left1 and n´back2. back rigth3 and front4
      M208 X0 Y-100 Z0 S1 ; set axis minima
      M208 X1000 Y1030 Z850 S0 ; set axis maxima
      M574 X2 S1 P"^22.io1.in" ; configure active-high endstop for high end on X via pin ^io3.in
      M574 Y2 S1 P"^20.io1.in+21.io1.in" ; configure active-high endstop for high end on Y via pin ^io1.in
      ; Z probe
      M558 P5 C"0.io1.in" H8 F2000 I0 T5000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
      G31 P200 X5 Y30 Z0 ; Set Z probe trigger value, offset and trigger height; Z probe
      M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
      M557 X50:800 Y50:800 S37.5 ; define mesh grid
      M308 S1 P"100.temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as PT1000 on pin 121.temp0
      M950 H1 C"100.out0" T1 ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 R1.553 C487.8 D10.35 S1.00 V0 ; disable bang-bang mode for heater and set PWM limit
      M143 H1 S250 ; set temperature limit for heater 1 to 250C
      M308 S2 P"101.temp0" Y"thermistor" T100000 B4138 ; configure sensor 2 as PT1000 on pin 121.temp0
      M950 H2 C"101.out0" T2 ; create nozzle heater output on out1 and map it to sensor 2
      M307 H2 B0 R1.553 C487.8 D10.35 S1.00 V0 ; disable bang-bang mode for heater and set PWM limit
      M143 H2 S250 ; set temperature limit for heater 1 to 250C
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M307 H0 B0 R0.243 C586.2 D33.87 S1.00 V0 ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0
      M143 H0 S120
      M563 P0 S"T0" D0 H1 F0 ; define tool 0
      G10 P0 R0 S0
      G10 P0 X0 Y0 Z0 ; set initial tool 0 active and standby temperatures to 0C
      M563 P1 S"T1" D1 H2 F2 ; define tool 1
      G10 P1 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
      G10 P1 X0 Y0 Z0
      M950 F0 C"100.out1" Q500 ; create fan 0 on pin 100.out1 and set its frequency
      M563 P0 D0 H1 ; tool uses extruder 0, heater 1
      M950 F1 C"100.out2" Q500 ; create fan 1 on pin 100.out2 and set its frequency
      M563 P0 D0 H1 F1 ; tool uses extruder 0, heater 1
      M950 F2 C"101.out1" Q500 ; create fan 2 on pin 101.out1 and set its frequency
      M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
      M563 P1 D1 H2 ; tool uses extruder 0, heater 2
      M950 F3 C"101.out2" Q500 ; create fan 3 on pin 101.out2 and set its frequency
      M106 P3 S1 H2 T45 ; set fan 3 value. Thermostatic control is turned on
      M563 P1 D1 H2 F2 ; tool uses extruder 1, heater 2
      ; Magnete
      M950 F8 C"2.out8" Q500 CMagnet0 ; create magnet 0 on pin out9 and set its frequency
      M950 F9 C"2.out7" Q500 CMagnet1 ; create magnet 0 on pin out9 and set its frequency
      M950 F10 C"21.out0" Q500 CMagnet2 ; create magnet 0 on pin out9 and set its frequency
      M950 F11 C"21.out1" Q500 CMagnet3 ; create magnet 0 on pin out9 and set its frequency
      G10 L1 P0 X-80 Y-80 Z-30.5
      G10 L1 P1 X-80 Y-80 Z-30.5
      T-1; Custom settings are not defined
      ; tpost0.g
      ; called before tool 0 is selected
      ;brush cooler
      M106 P0 S0
      ;Move in
      G1 X452 Y30 F5000
      ;Collect
      G1 X452 Y-15 F4000
      ;Close Coupler
      M98 P"/macros/Coupler - Lock"
      ;Magnet 0 prozent
      M106 P10 S0
      M106 P11 S0
      M116 H1 S3
      G92 E1
      G1 F800 E0.0
      G92 E0
      ;WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING!
      ;if you are using non-standard length hotends ensure the bed is lowered enough BEFORE undocking the tool!
      G91
      G1 Z10 F400
      G90
      ;Move Out
      G1 X452 Y30 F2000
      ; tfree0.g
      ; called when tool 0 is freed
      ;Drop the bed
      G91
      G1 Z4 F1000
      G90
      ;Move In
      G53 G1 X452 Y30 F12000
      ;Magnet 100 prozent
      M106 P10 S1
      M106 P11 S1
      ;brush cooler
      M106 P0 S1
      ;touch
      G53 G1 X452 Y-15
      ;Open Coupler
      M98 P"/macros/Coupler - Unlock"
      ;fan off
      M106 P2 S1
      ;Move Out
      G53 G1 X452 Y-154 F7000
      ;magnet 50 prozent
      M106 P10 S0.5
      M106 P11 S0.5
      • Phaedruxundefined Phaedrux referenced this topic
      • A Former User?
        A Former User @A Former User
        @gruna-studio
        Newer g code available. I'll upload it ASAP
        R.G.
        edit
        Tpost is now in tpre.
        Now I can pick up tools, but no offset applies.
        G90                                                        ; send absolute coordinates...
        M83                                                        ; ...but relative extruder moves
        M552 s1
        t-1
        G4 S4
        M574 C1 S3
        M574 C0 Z0
        M569 P0.3 S1
        M569 P0.5 S0
        M569 P110.0 S0                                              ; physical drive 0.2 goes forwards
        M584 X22.0 Y20.0:21.0 Z0.0:0.1:0.2:0.3 C0.5 E100.0:110.0                         ; set drive mapping
        ; Z probe
        M140 H0
        M143 H0 S120
        M308 S1 P"100.temp1" Y"thermistor" T100000 B4138           ; configure sensor 1 as PT1000 on pin 121.temp0
        M143 H1 S250
        M308 S2 P"110.temp0" Y"thermistor" T100000 B4138            ; configure sensor 2 as PT1000 on pin 121.temp0
        M950 H2 C"110.out0" T2                                         ; create nozzle heater output on out1 and map it to sensor 2
        M950 F2 C"110.out1" Q500                                    ; create fan 2 on pin 101.out1 and set its frequency
        M950 F3 C"110.out2" Q500                                    ; create fan 3 on pin 101.out2 and set its frequency
        ; Magnete
        M563 P0 D0 H1 F0                                           ; define tool 0
        G10  X-80 Y-80 Z-30.5                                             ; set initial tool 0 active and standby temperatures to 0C
        G10 P0 R0 S0
        M563 P1  D1 H2 F2                                          ; define tool 1                                          ; set initial tool 0 active and standby temperatures to 0C
        G10 R0 S0 X-80 Y-80 Z-30.5
        G10 P1 R0 S0
          dc42 administrators @A Former User
          @gruna-studio said in Tool not picking up:
          When tpre is run the tool has not yet been activated, so tool offsets are not applied.
