    Echo output to file - expected expression
    Gcode meta commands
    • thomas.weiss
      thomas.weiss last edited by
      Hey,
      I am trying to programmaticlly store a command in a macro file (from a macro file), but I'm having problems with both ways of achieving this:
      The goal is to write a G10 L20 Z{variable} into a macro file.
      Option A - M28
      var z_offset = move.axes[2].machinePosition * -1
      echo "G10 L20 Z"{var.z_offset}
      M30 "0:/macros/Experimental/apply_z_offset" ; First delete the old file
      M28 "0:/macros/Experimental/apply_z_offset" ; Create a new one
      G10 L20 Z{var.z_offset}
      M29
      The first echo outputs exactly what I want to be written into the apply_z_offset file: "G10 L20 Z5.000"
      The file itself now holds this line - it doesn't write the variables content:
      Option B - echo>
      I've seen people having similar problems that got solved by writing to the file via echo ><filename> <expression>
      echo >"0:/macros/Experimental/apply_z_offset" "G10 L20 Z"^{var.z_offset}
      This gives me a "Error: meta command: expected an expression"
      I tried the echo to file alone in different variations, but I am still getting the same error:
      • echo >"0:/testfile.g" "Hello World"
      • echo >"0:/testfile.g" {"Hello World"}
      • echo >"0:/testfile.g" 1
      • echo >"0:/testfile.g" {move.axes[2].machinePosition}
      What am I doing wrong here? Any ideas?
      Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.3RC2 (2021-05-11)
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @thomas.weiss last edited by
        @thomas-weiss i would update your firmware to 3.4RC2 and try again
        • thomas.weiss
          @jay_s_uk I see - you are right. Echo to file was added in 3.4, an update should solve this. Thank you!
          Sadly, we'll need our prototype for a presentation in the upcoming days and I don't want to risk that a firmware update changes or breaks any functionality that we already implemented.
          Might have to go without this function for now.
