    Some advice for my Endstops
    • Tim-C.undefined
      Tim-C.
      Hi, once again I am running into a Problem while setting up my first Duet 2 Wifi board. I cant get the inductic endstops from the Sidewinder X1 to work. The Consol output is:
      • M119 Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped
        and
      • M574
        Endstop configuration:
        X: low end switch connected to pin !xstop
        Y: low end switch connected to pin !ystop
        Z: low end Z probe
      The status does not change when they should be triggerd or not.
      config.h is:
      M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      G31 P500 X33 Y-47 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X15:285 Y15:285 S67.5 ; define mesh grid
      The +5V for all the Endstops and BLTouch is comming from P1 on the Expansion.
      What am I missing? Is there a nother way to messure the functionality?
      Best Regards Tim
      Phaedruxundefined fcwiltundefined Gixxerfastundefined 3 Replies Last reply Reply Quote 0
        Phaedrux Moderator @Tim-C.
        @tim-c said in Some advice for my Endstops:
        Can you describe more what you mean by this?
        • fcwiltundefined
          fcwilt @Tim-C.
          Do you have any electrical specifications for your inductive sensors?
          They are often not compatible with the Duet 2 endstop connections.
          Can you also please post a picture of one of the endstop connections to show the wiring from the inductive sensor.
          • Gixxerfastundefined
            Gixxerfast @Tim-C.
            @tim-c Without knowing for sure since I do not not own such a printer, a little bit of googling suggests that these are 12-24V NPN inductive sensors which means that they require at least 12V to work reliably.
            Have a look in this old thread: https://forum.duet3d.com/topic/12056/npn-12v-endstops-at-duet-wifi
            If this is correct, it will behave as my old PL-08N2 inductive probe and output near input voltage when near a metal object. Just make sure that your input port can handle the higher (>3.3V signal) voltage.
            Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
            Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
            Ender 3 Pro with BTT SKR-2 + RRF
            • droftartsundefined droftarts referenced this topic
