    Writing M122 to file
    Gcode meta commands
    • Piet
      Piet last edited by
      Dear users,
      I'm wondering if there is a way to write the diagnostics output of the M122 command to a text file using meta Gcode.
      Thanks in advance, Piet.
      • T3P3Tony
        T3P3Tony administrators @Piet last edited by
        @Piet
        there is not currently a way to echo it directly to a file however the logging function can be used, e.g.:
        M929 P{"M122_Log"^{state.upTime}^".txt"} S3
        M122
        M929 S0
        If you put that in a macro then everytime you run it a new log file will be created with the output of M122.
        Note this wont work if you are already logging to another file
        www.duet3d.com
