    NEEBE: How to send gcode through python
    DSF Development
    • chernogorskyundefined
      chernogorsky
      Quite a newbe to Python DSF. may you please point me to the right direction
      I'd like to be able to send multiple commands to Duet through python
      Thanks
      • T3P3Tonyundefined
        T3P3Tony administrators @chernogorsky
        @chernogorsky have you seen the example here:
        https://github.com/Duet3D/dsf-python/blob/main/examples/send_simple_code.py
        once you have that working then you can base a python script on the premise to get your gcode stream and send it. you will probably need to leave the connection open between commands (not open and close it per command). @chrishamm may be able to comment about best practices for the connection (permanently open, idle close etc).
        That python library implements bindings for the DSF IPC API which has more information here:
        https://github.com/Duet3D/DuetSoftwareFramework/wiki/API-Overview
        www.duet3d.com
        chernogorskyundefined 1 Reply Last reply Reply Quote 1
          chernogorsky @T3P3Tony
          @t3p3tony Thank you
          and following our conversation the other day
          pendant video
          Next newbe question would be how to set it as a plugin
          • pjlundefined
            pjl
            This post is deleted!
            • infiniteloopundefined infiniteloop referenced this topic
