    Store Last Z Height from prior print
    Gcode meta commands
    • TheIndianDude
      TheIndianDude last edited by TheIndianDude
      I was wondering if the microcontrollers on the Duet 2 or Duet 3 have enough memory so that the max Z height from the last print is stored in memory before the print is finished. This way, when a new print is started and the printer has to home on Z, it can recall that saved height and start from a potentially known position (not as an accurate height, but a starting point of reference to assist with homing). This can avoid overtravel since most homing moves require the Z axis to move away from the print head (usually 5 or 10 mm) and if the prior print used the printer's full Z capacity, then there would be no more Z travel left and it puts unnecessary strain on the motors.
      If this value can be stored, is there a way it can be stored using ending G-Code?
      OwenD 1 Reply Last reply Reply Quote 0
      • OwenD
        OwenD @TheIndianDude last edited by OwenD
        @theindiandude
        You can use the echo command to write the last known Z position to a macro and then use that same macro to create a global variable on restart.
        First create a macro to save the position to a file for later re-use
        ;0:/macros/SaveLastZ.g  - called at the end of print to record last used Z position
        echo >"0:/macros/lastZ.g" "if !exists(global.lastZ)"
        echo >>"0:/macros/lastZ.g" "   global lastZ=" ^ move.axes[2].userPosition
        echo >>"0:/macros/lastZ.g" "else"
        echo >>"0:/macros/lastZ.g" "   set global.lastZ=" ^ move.axes[2].userPosition
        In your end code you can put
        M98 P"0:/macros/SaveLastZ.g"
        then in your homing file use
        EDIT: Changed so that it takes into account whether the machine is already homed and knows where it is
        if move.axes[2].userPosition = 0 ; we don't know where we are, so call the macro
        	M98 P"0:/macros/lastZ.g" ; call the macro to create the global variable with the last known position
        	if result != 0 ; the macro call was successful
        		echo "macro failed"
        else ; we do know where we are, so rreset the global or create it if need be
        	if exists(global.LastZ)
        		set global.LastZ = move.axes[2].userPosition
        	else
        		global LastZ = move.axes[2].userPosition
        if global.lastZ < move.axes[2].max - 10
        	G91 ; set relative positioning
        	G1 H2 Z10 F120
        	G90 ; set absolute positioning
        	echo "Z lifted"
        ; rest of homing file is not indented
        Anything in the indented section will only happen if the last known position is greater than 10mm from the max Z position.
        Note that the macro won't exist until after your first print unless you create it manually.
        If it doesn't exist then it will skip the raising section.
        TheIndianDude 2 Replies Last reply Reply Quote 2
        • TheIndianDude
          TheIndianDude @OwenD last edited by
          @owend This is super cool! I didn't know RRF supported conditional GCode. Now I need to learn how to program in this language.
          Thanks a bunch!
          • TheIndianDude
            @owend quick question. I'm assuming move.axes(2) refers to motor driver 2 which is usually mapped to the Z axis. What if I have multiple independent Z (my printer has drives 5, 6, and 7 mapped to z on a Duex 5)? Can I use any one of those drive numbers?
            • Moved from General Discussion by  Phaedrux Phaedrux
            • OwenD
              OwenD last edited by OwenD
              @theindiandude
              No, move.axes[2] refers to the axis, not the drivers.
              I have two Z axis drives.
              If you send
              echo move.axes[2].letter
              from the console it will confirm.
