    Printer resetting after print upgrade from version 3.3 to 3.4.
    Beta Firmware
    • trobisonundefined
      trobison
      I have recently upgraded from version 3.3 to version 3.4, and have a few issues. I have never seen this before, only since I have upgraded to version 3.4.
      It looks like a software reset.
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet Ethernet 1.02 or later + DueX5
      Board ID: 0JD0M-9P6M2-NWNS0-7J9DJ-3SJ6S-K90RJ
      Used output buffers: 1 of 24 (24 max)
      Static ram: 23868
      Dynamic ram: 73160 of which 0 recycled
      Never used RAM 11524, free system stack 110 words
      Tasks: NETWORK(ready,26.3%,212) HEAT(notifyWait,0.1%,332) Move(notifyWait,0.5%,283) DUEX(notifyWait,0.0%,24) MAIN(running,73.1%,440) IDLE(ready,0.0%,30), total 100.0%
      Owned mutexes:
      Last reset 00:54:59 ago, cause: power up
      Last software reset at 2022-03-18 12:04, reason: User, GCodes spinning, available RAM 14524, slot 1
      Error status: 0x04
      Aux0 errors 0,0,0
      Step timer max interval 0
      MCU temperature: min 30.3, current 32.5, max 39.1
      Supply voltage: min 23.9, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/68/68, gc cycles 0
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 0
      Driver 1: standstill, SG min 0
      Driver 2: standstill, SG min 0
      Driver 3: standstill, SG min n/a
      Driver 4: standstill, SG min 0
      Driver 5: standstill, SG min n/a
      Driver 6: standstill, SG min n/a
      Driver 7: standstill, SG min 0
      Driver 8: standstill, SG min n/a
      Driver 9: standstill, SG min n/a
      Driver 10:
      Driver 11:
      Date/time: 2022-03-18 20:35:19
      Slowest loop: 179.97ms; fastest: 0.14ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 4.1ms, write time 4.5ms, max retries 0
      DMs created 83, segments created 28, maxWait 282993ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 1628, completed 1628, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty
      === DueX ===
      Read count 1, 0.02 reads/min
      === Network ===
      Slowest loop: 203.96ms; fastest: 0.02ms
      HTTP sessions: 2 of 8
      Interface state active, link 100Mbps full duplex
        Was that M122 gathered after the reset?
        That indicates it was a power cycle that caused the last reset.
        Can you give more details about what issues you're seeing exactly?
        trobisonundefined 1 Reply Last reply Reply Quote 0
        • trobisonundefined
          trobison @Phaedrux
          @phaedrux
          Hi Phaedrux, Since the update, there are only a few things I have noticed. M0 doesn't turn off the heaters as it did earlier with v3.3.
          The printer was losing all home information on completion of a print. I tried an experiment and copied my End-Gode from Prusa Slicer to notepad, and the same with SuperSlicer and compared the two. They were the same. I deleted all content in SuperSlicer End-Gcode field, and copied and paste the content from PrusaSlicer. Guess what, it retained all home position at the end of a print. Perhaps an invisible character was in the End-gcode field. The g-code created by the slicer showed no reason for the lost home positions.
          I am still experiencing network dropout during prints. They are not there while the printer is idle (very random drops while sitting idle). During a print, the network drops out are quite bad. This has been an ongoing thing with my Duet 2. This is reproducible.
          This is my working End-GCode
          ; Run custom end G-code
          G91    			; use relative positioning
          G1 Z5 F1000 		; Drop Bed 5mm
          G90    			; use absolute positioning
          T-1    			; Drop off the tool
          G29 S2 			; Disable Mesh Compensation.
          G1 X5 Y5 F10000 	        ; Park gantry
          M140 H0 		        ; Set bed heater to 0
          M568 P0 R0 S0		; Set T0 off
          M568 P1 R0 S0		; Set T1 off
          M568 P2 R0 S0		; Set T2 off
          M568 P3 R0 S0		; Set T3 off
          • Phaedruxundefined Phaedrux moved this topic from Firmware installation
            Phaedrux Moderator @trobison
            @trobison said in Printer resetting after print upgrade from version 3.3 to 3.4.:
            Where did you have M0 in your end gcode?
            • trobisonundefined
              trobison @Phaedrux
              @phaedrux It was on the last line of end gcode. This configuration was working for many months at version 3.3. After the upgrade, it stopped working. I tried typing a M0 command into the console after the print job was completed and the heaters failed to turn off. The M0 command did nothing, the heaters remained at their standby temps.
              I the end I have commands that turn off all heaters in the end gode. It works, but I thought a simple M0 should work.
                Yes you're not the first person to notice a difference in behaviour with M0. There was a change noted in the release notes of 3.4 but I don't know if it's behaving as expected right now.
