    DCS won't start after 3.4.0 Update
    Firmware installation
    • Kermit
      Kermit last edited by
      Tried to update from 3.3 to 3.4 on my Duet 3+ SBC today.
      Updated like described here: https://docs.duet3d.com/User_manual/Machine_configuration/SBC_setup
      sudo apt update
      sudo apt upgrade
      Update finished without errors but now DuetControlServer won't start.
      Can't access via webcontrol, SSH works without a problem.
      running Journalctl on duetcontrolserver indicates incompatible firmware even though reprapfirmware is now also 3.4.0.-1
      Is there a way to fix the problem on my system without going through the trouble of flashing a new image?
      Mar 19 20:00:09 ToolChanger systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 343.
      Mar 19 20:00:09 ToolChanger systemd[1]: Stopped Duet Control Server.
      Mar 19 20:00:09 ToolChanger systemd[1]: Starting Duet Control Server...
      Mar 19 20:00:09 ToolChanger DuetControlServer[8399]: Duet Control Server v3.4.0
      Mar 19 20:00:09 ToolChanger DuetControlServer[8399]: Written by Christian Hammacher for Duet3D
      Mar 19 20:00:09 ToolChanger DuetControlServer[8399]: Licensed under the terms of the GNU Public License Version 3
      Mar 19 20:00:10 ToolChanger DuetControlServer[8399]: [info] Settings loaded
      Mar 19 20:00:10 ToolChanger DuetControlServer[8399]: [info] Environment initialized
      Mar 19 20:00:10 ToolChanger DuetControlServer[8399]: [warn] Incompatible firmware, please upgrade as soon as possible
      Mar 19 20:00:10 ToolChanger DuetControlServer[8399]: [info] Connection to Duet established
      Mar 19 20:00:10 ToolChanger DuetControlServer[8399]: [info] IPC socket created at /run/dsf/dcs.sock
      Mar 19 20:00:10 ToolChanger systemd[1]: Started Duet Control Server.
      Mar 19 20:00:11 ToolChanger DuetControlServer[8399]: [fatal] Abnormal program termination
      Mar 19 20:00:11 ToolChanger DuetControlServer[8399]: [fatal] Update task faulted
      Mar 19 20:00:11 ToolChanger DuetControlServer[8399]:    System.ArgumentException: Requested value 'daa' was not found.
      Mar 19 20:00:11 ToolChanger DuetControlServer[8399]:    at System.Enum.TryParseByName(RuntimeType enumType, ReadOnlySpan`1 value, Boolean ignoreCase, Boolean throwOnFailure, UInt64& result)
      Mar 19 20:00:11 ToolChanger DuetControlServer[8399]:    at System.Enum.TryParseInt32Enum(RuntimeType enumType, ReadOnlySpan`1 value, Int32 minInclusive, Int32 maxInclusive, Boolean ignoreCase, Boolean throwOnFailure, TypeCode type, Int32& result)
      Mar 19 20:00:11 ToolChanger DuetControlServer[8399]:    at System.Enum.TryParse(Type enumType, ReadOnlySpan`1 value, Boolean ignoreCase, Boolean throwOnFailure, Object& result)
      Mar 19 20:00:11 ToolChanger DuetControlServer[8399]:    at System.Enum.Parse(Type enumType, String value, Boolean ignoreCase)
      Mar 19 20:00:11 ToolChanger DuetControlServer[8399]:    at DuetAPI.Utility.JsonLowerCaseStringEnumConverter.JsonLowerCaseStringEnumConverterInner`1.Read(Utf8JsonReader& reader, Type typeToConvert, JsonSerializerOptions options) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPI/Utility/JsonLowerCaseStringEnumConverter.cs:line 59
      Mar 19 20:00:11 ToolChanger DuetControlServer[8399]:    at System.Text.Json.Serialization.JsonConverter`1.TryRead(Utf8JsonReader& reader, Type typeToConvert, JsonSerializerOptions options, ReadStack& state, T& value)
      Mar 19 20:00:11 ToolChanger DuetControlServer[8399]:    at System.Text.Json.Serialization.JsonConverter`1.ReadCore(Utf8JsonReader& reader, JsonSerializerOptions options, ReadStack& state)
      Mar 19 20:00:11 ToolChanger DuetControlServer[8399]:    at System.Text.Json.Serialization.JsonConverter`1.ReadCoreAsObject(Utf8JsonReader& reader, JsonSerializerOptions options, ReadStack& state)
      Mar 19 20:00:11 ToolChanger DuetControlServer[8399]:    at System.Text.Json.JsonSerializer.ReadFromSpan[TValue](ReadOnlySpan`1 utf8Json, JsonTypeInfo jsonTypeInfo, Nullable`1 actualByteCount)
      Mar 19 20:00:11 ToolChanger DuetControlServer[8399]:    at System.Text.Json.JsonSerializer.ReadFromSpan[TValue](ReadOnlySpan`1 json, JsonTypeInfo jsonTypeInfo)
      Mar 19 20:00:11 ToolChanger DuetControlServer[8399]:    at System.Text.Json.JsonSerializer.Deserialize(String json, Type returnType, JsonSerializerOptions options)
      Mar 19 20:00:11 ToolChanger DuetControlServer[8399]:    at DuetAPI.ObjectModel.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPI/ObjectModel/Base/ModelObject.cs:line 328
      Mar 19 20:00:11 ToolChanger DuetControlServer[8399]:    at DuetAPI.ObjectModel.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPI/ObjectModel/Base/ModelObject.cs:line 309
      Mar 19 20:00:11 ToolChanger DuetControlServer[8399]:    at DuetAPI.ObjectModel.ObjectModel.InternalUpdateFromJson(String key, JsonElement jsonElement, Boolean ignoreSbcProperties, Int32 offset, Boolean last) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPI/ObjectModel/ObjectModel.cs:line 199
      Mar 19 20:00:11 ToolChanger DuetControlServer[8399]:    at DuetAPI.ObjectModel.ObjectModel.UpdateFromFirmwareJson(String key, JsonElement jsonElement, Int32 offset, Boolean last) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPI/ObjectModel/ObjectModel.cs:line 149
      Mar 19 20:00:11 ToolChanger DuetControlServer[8399]:    at DuetControlServer.Model.Updater.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 223
      Mar 19 20:00:12 ToolChanger DuetControlServer[8399]: [info] Application has shut down
      Mar 19 20:00:12 ToolChanger systemd[1]: duetcontrolserver.service: Main process exited, code=exited, status=70/SOFTWARE
      Mar 19 20:00:12 ToolChanger systemd[1]: duetcontrolserver.service: Failed with result 'exit-code'.
      Mar 19 20:00:12 ToolChanger systemd[1]: duetcontrolserver.service: Service RestartSec=100ms expired, scheduling restart.
      Mar 19 20:00:12 ToolChanger systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 344.
      Mar 19 20:00:12 ToolChanger systemd[1]: Stopped Duet Control Server.
      Mar 19 20:00:12 ToolChanger systemd[1]: Starting Duet Control Server...
      Mar 19 20:00:12 ToolChanger DuetControlServer[8422]: Duet Control Server v3.4.0
      Mar 19 20:00:12 ToolChanger DuetControlServer[8422]: Written by Christian Hammacher for Duet3D
      Mar 19 20:00:12 ToolChanger DuetControlServer[8422]: Licensed under the terms of the GNU Public License Version 3
      Mar 19 20:00:13 ToolChanger DuetControlServer[8422]: [info] Settings loaded
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @Kermit last edited by
        @kermit is it a 6HC?
        Can you connect to it via USB with yat and check the firmware version?
        Send M115
        • Kermit
          Kermit last edited by Kermit
          I don't have Windows at home so I used Minicom directly from the SBC instead.
          Connecting with the 6HC kind of worked but all I get is "Connection to Linux established!" and "Lost connection to Linux" every 2 seconds.
          EDIT:
          stopped DCS service and was able to send the M115
          Result:
          FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3,3 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2021-06-15 21:45:56
          Apparently the board itself didn't get the update automatically like I anticipated. I'll try to update it manually now.
          chrishamm 1 Reply Last reply Reply Quote 1
          • chrishamm
            chrishamm administrators @Kermit last edited by
            @kermit You don't have RRF 3.4 installed yet, please upgrade it either via the reprapfirmware package (by running sudo apt install --reinstall reprapfirmware from a Linux terminal and then confirm the prompt) or using the DCS upgrade command (/opt/dsf/bin/DuetControlServer -u). DAA is no longer supported by software version 3.4, so it refuses to connect normally. That should not interfere with a firmware update, though.
            Duet software engineer
            Kermit 1 Reply Last reply Reply Quote 0
            • Kermit
              Put the files from /opt/dsf/sd on the SBC + new Firmware files onto a SD Card and did a manual firmware-update by sending M997 S0 with Minicom.
              DCS is working again!
              M115 readout:
              FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.0 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2022-03-15 18:57:26
              Next time I'll make sure to update the Mainboard firmware before doing any SBC Updates 😅
              • Kermit
                Kermit @chrishamm last edited by Kermit
                @chrishamm said in DCS won't start after 3.4.0 Update:
                Already tried this before but it didn't change anything, the firmware on the mainboard stayed the same.
                probably due to the connection errors triggered by the duetcontrolserver.service "bootloop"
                I didn't manage to get any commands over the com-connection until i killed the service
