    Solved Impossible to connect on my Duet board.
    Duet Web Control
    • CNCProblem
      CNCProblem last edited by
      Hi everyone,
      I have a problem with the Duet 2 wifi V1.04, I can activate the wifi card and access the duet web control, but I cannot connect to the card with the connect button.
      I flashed the firmware several times, nothing changes. (The firmware install on the board is "Duet2CombinedFirmware")
      This is a screenshot of my control web page and the connect button remains blue.
      If you have the same issues, or you have the solution please let me know.
      Thank for you reply. Bye.
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @CNCProblem last edited by
        @cncproblem what firmware version are you running? you can check with M115
        thats a really old version of DWC so thats probably your issue
        CNCProblem 1 Reply Last reply Reply Quote 0
        • CNCProblem
          CNCProblem @jay_s_uk last edited by
          @jay_s_uk I use this firmware
          • jay_s_uk
            @cncproblem then update DWC from here https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0/DuetWebControl-SD.zip
            i suggest removing the contents of the www folder and replacing them with the contents of that zip file
            CNCProblem 1 Reply Last reply Reply Quote 1
            • CNCProblem
              @jay_s_uk It WORK, thank for you help, I have delete and replace www microSD's folder and it work.
              • Topic has been marked as a question  Phaedrux Phaedrux
              • Topic has been marked as solved  Phaedrux Phaedrux
