    Extrusion Options Extrude/Retract Greyed Out - Please Help
    Duet Web Control
    • Ripeds_O3Pundefined
      Ripeds_O3P
      So I made the jump to DWC 3.4.0. Updated the firmware to the latest version. Updated the files as well.
      Auto-tuned the nozzle and bed heaters. Updated the config file with the new lines (Nozzle example: M307 H1 R3.938 K1.379:1.484 D7.52 E1.35 S1.00 B0 V24.1).
      Now the extrustion control options are greyed out (unusable) for extrude/retract when I hit 205 on the nozzle. It worked at 160 celcius on previous versions. And I'm at a loss on what the issue is.
      Did I do something wrong during the PID tuning? This is probably a dumb question, but hey, I may as well have been born yesterday on the subject of firmware. Is the target temperature meant to push it to a high temp close to the limit of the heater to get good data from the sensor back? Or is the target temp the bare minimum that allows the extruder to function while also testing the sensor?
      Or is there some other setting I messed up on? Another line of code that needs changing/defining after auto-tuning the nozzle heater?
      I've quoted my config.g file below:
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Mar 22 2022 06:30:04 GMT-0700 (Pacific Daylight Saving Time)
      G90                                              ; send absolute coordinates...
      M83                                              ; ...but relative extruder moves
      M550 P""                               ; set printer name
      M551 P""                                    ; set password
      M552 S1                                          ; enable network
      M586 P0 S1                                       ; enable HTTP
      M586 P1 S0                                       ; disable FTP
      M586 P2 S0                                       ; disable Telnet
      M569 P0 S0                                       ; physical drive 0 goes backwards
      M569 P1 S1                                       ; physical drive 1 goes forwards
      M569 P2 S0                                       ; physical drive 2 goes backwards
      M569 P3 S1                                       ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                 ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                          ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E311.00                ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00              ; set maximum instantaneous speed changes (mm/min)
      M203 X1080000.00 Y1080000.00 Z162000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z500.00 E250.00             ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                     ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                          ; Set idle timeout
      M208 X0 Y0 Z0 S1                                 ; set axis minima
      M208 X223 Y223 Z213 S0                           ; set axis maxima
      M574 X1 S1 P"!xstop"                             ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !xstop
      M574 Y2 S1 P"!ystop"                             ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin !ystop
      M574 Z2 S1 P"!zstop"                             ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin !zstop
      M558 P0 H5 F120 T6000                            ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20                         ; define mesh grid
      M308 S0 P"spi.cs1" Y"rtd-max31865"                         ; configure sensor 0 as PT100 on pin spi.cs1
      M950 H0 C"bedheat" T0                                      ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 R0.204 K0.220:0.000 D2.29 E1.35 S1.00 B0           ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                    ; map heated bed to heater 0
      M143 H0 S120                                               ; set temperature limit for heater 0 to 120C
      M308 S1 P"spi.cs2" Y"rtd-max31865"                         ; configure sensor 1 as PT100 on pin spi.cs2
      M950 H1 C"e0heat" T1                                       ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 R3.938 K1.379:1.484 D7.52 E1.35 S1.00 B0 V24.1     ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S290                                               ; set temperature limit for heater 1 to 290C
      M950 F0 C"fan0" Q500                             ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S1 H-1                                   ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                             ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                                ; set fan 1 value. Thermostatic control is turned on
      M563 P0 S"Nozzle-0" D0 H1 F0                     ; define tool 0
      G10 P0 X0 Y0 Z0                                  ; set tool 0 axis offsets
      G10 P0 R0 S0                                     ; set initial tool 0 active and standby temperatures to 0C
      If it's easier to download and read, here's my config.g
      Lo-Fiundefined 1 Reply Last reply Reply Quote 0
      • Lo-Fiundefined
        Lo-Fi @Ripeds_O3P
        @ripeds_o3p
        If I recall correctly, I had to create and select a filament as well as select the tool by clicking on it in DWC. It puzzled me for a bit too!
          You should also add a T0 to the end of your config.g to ensure a tool is selected at startup.
          Ripeds_O3Pundefined 1 Reply Last reply Reply Quote 1
            Ripeds_O3P @Phaedrux
            @phaedrux That fixed it! Thanks! ^.^
            T0						 ; ensures a tool is selected upon start up (allowing extrusion/retraction)
            Added a note in the config to remind myself what it does.
