Duet 2 Ethernet: can not install or connect to DWC
Duet Web Control
262
  • undefined
    equipment66
    Hello everybody,
    I have unpacked my Duet 2 Ethernet board ant trying to start it. However, unsuccesfully :(. Could maybe somebody to help me a little bit?
    I have installed Mellow Fly board on my Ender3 before. It was a litle bit... complicated too 🙂
    What I already did:
    I connected to board with YAT and configured network connection according to https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7. The board is visible on the net and I can ping it.
    2) I have configured and placed firmware to SD card.
    However, I can not connect to DWC frm my browser. The answer is "Your Duet rejected the HTTP request: page not found"
    Could maybe someone help me with this? 😕
    undefined 1 Reply Last reply 23 Mar 2022, 10:52 Reply Quote 0
    • undefined
      jay_s_uk @equipment66
      @equipment66 there's an issue with how you've configured the SD card then.
      there should be a folder called www in the root of the sd card with the DWC zip contents extracted into it
      undefined 1 Reply Last reply 23 Mar 2022, 11:10 Reply Quote 0
      • undefined
        equipment66 @jay_s_uk
        @jay_s_uk, thanks for reply.
        Actualy, I have www folder on SD card.
        Could I find somewhere any exampe of right content for this folder? Mostly likely I'm simply missing of one or few important files.
        undefined 1 Reply Last reply 23 Mar 2022, 11:14 Reply Quote 0
        • undefined
          @equipment66 assuming you're running RRF 3.4, just extract the contents of this zip file https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0/DuetWebControl-SD.zip
          undefined 1 Reply Last reply 23 Mar 2022, 11:31 Reply Quote 0
          • undefined
            @jay_s_uk ,
            ... and no result. Can I perform any diagnostic tests via YAT?
            • undefined
              @equipment66 what version of RRF are you on? post an output of M115
              undefined 1 Reply Last reply 23 Mar 2022, 11:35 Reply Quote 0
              • undefined
                @jay_s_uk,
                v2.0
                undefined 1 Reply Last reply 23 Mar 2022, 11:40 Reply Quote 0
                • undefined
                  @equipment66 ok then, if this is the first time setting it up I suggest not even bothering with v2 and jumping straight into 3.4
                  follow the instructions here and BOSSA the board up to 3.4
                  https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware#all-other-duet-boards
                  undefined 1 Reply Last reply 23 Mar 2022, 12:41 Reply Quote 0
                  • undefined
                    @jay_s_uk, strange.
                    It looks, I need files iap4e and iap4s.bin for updating firmware.
                    I have read, I need specific files files for each wersion of firmware.
                    But I cant find: https://github.com/Duet3D/RepRapFirmware/releases
                    Do you know, where I can I get it? 😕
                    undefined 1 Reply Last reply 23 Mar 2022, 12:43 Reply Quote 0
                    • undefined
                      @equipment66 you need those if updating using M997. If you using BOSSA, you don't
                      If you want to go the long way you need to update from 2.0 to 2.05.1 then from 2.05.1 to 3.0, then 3.0 to 3.4
                      BOSSA is easier when coming from v2
                      undefined 1 Reply Last reply 23 Mar 2022, 13:29 Reply Quote 0
                      • undefined
                        @jay_s_uk, oh, at least 👍
                        thank you for your support !
                        1 out of 11
