    Paneldue 5i V1 with DUET2 wifi FW3.4 ?
    • Highländer1972undefined
      Highländer1972
      Solved I had a loose pin. Now it works-
      I have an Paneldue 5i V1 updated to FW 1.24. and a duet2 wifi FW 3.4 the Panel is grey dark with backlight on.
      Since the newer FW does not work on V1 is it possible to use a panel V1 with a duet FW 3.4?
      The panel is activated with M575 P1 B57600 S1 in the config file.
      Regards,
      Stefan
        dc42 administrators @Highländer1972
        @highländer1972 all integrated versions of PanelDue (5i and 7i) can run all versions of PanelDue firmware. It's only the non-integrated versions using V1 and some V2 PCB revisions that can't run anything later than 1.25.
        Highländer1972undefined 1 Reply Last reply Reply Quote 0
          Highländer1972 @dc42
          Thanks for the answer.
          The problem is solved, I just had a loose pin in the connector.
          Stefan
