    Duet Web Control 3.4.0 auto sleep
    Duet Web Control
    • jjudeundefined
      jjude
      I don't see a choice?!?
      • chrishammundefined
        chrishamm administrators @jjude
        @jjude Auto-sleep was removed from DWC because it tried to provide a controller feature in the UI (see changelog). If you want to turn off the heaters once a print is finished, consider adding M1 to your end G-code or implement your own logic in daemon.g.
        Duet software engineer
        jjudeundefined 1 Reply Last reply Reply Quote 0
        • jjudeundefined
          jjude @chrishamm
          @chrishamm Too bad that was removed.
          Can I send GCODE from an external program via Wi-Fi?
            @jjude Yes you can do that or just use the input box at the top or the G-code console.
            • jjudeundefined
              jjude @chrishamm
              @chrishamm
              Can you give an example of how I can send GCODE if the IP of my printer is 123.123.321.3 ?
              MintyTreborundefined 1 Reply Last reply Reply Quote 0
              • MintyTreborundefined
                MintyTrebor @jjude
                @jjude
                https://github.com/Duet3D/RepRapFirmware/wiki/HTTP-requests
                rr_gcode should work for you
                NodeDSF - Native Node-Red integration with Duet boards.
                BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
                ReleaseMgr - Duet update info inside DWC.
                Repo
