    DWC plugin required
    Duet Web Control
    • moth4017
      moth4017 last edited by
      Hi If anyone is interested in doing a plug in for us please PM me.
      Scope:-
      Serial Data into the USB port on Duet3 to be displayed in DWC .
      e.g "text to be displayed" "Location in DWC"
      This is to allow a Micro (ardino) to send data to be displayed in DWC.
        dc42 administrators @moth4017 last edited by
        @moth4017 I think the first step would be for you to get the Arduino to wrap up each message in a M118 command addressed to HTTP.
        moth4017 1 Reply Last reply Reply Quote 0
        • moth4017
          moth4017 @dc42 last edited by
          if i use the USB with M118
          e.g
          M118 P1 S"Hello Console and DWC" L2 ; display in Console message
          What is the Baud rate , Data bits, stop bits , parity ?
          MintyTrebor dc42 2 Replies Last reply Reply Quote 0
          • MintyTrebor
            MintyTrebor @moth4017 last edited by
            @moth4017 These are the settings I use to work with serial :
            Alternative approach which might work for you:
            Define one or more global variables (according to number of data points etc) in config.g eg
            global mySerialVar1 = 0
            global mySerialVar2 = "Offline"
            Use the Arduino serial to set the values of these variables with the command(s)
            set global.mySerialVar1 = ######
            set global.mySerialVar2 = "Some Text"
            Use BtnCmd Plugin, and add object model value panels like this:
            Your data will now display in DWC similar to other data, and update in realtime as the Arduino updates the values of the global variables eg:
            NodeDSF - Native Node-Red integration with Duet boards.
            BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
            ReleaseMgr - Duet update info inside DWC.
            Repo
              @moth4017 said in DWC plugin required:
              e.g
              8 data bits. The rest doesn't matter because all Duets have a true USB port.
              • moth4017
                @moth4017
                thanks very much , this gives me a good p[lace to start.
                cheers Mark
