Movement
  • Hi All
    I need some help with a little problem
    I need to set the corner of the bead so it is 0,0
    I can get it to work on X but not on Y
    The distance is
    X=40 mm
    Y=57 mm
    The corner is at the top left corner
    Down below is the code
    The bed can only move 205 mm in Y direction after homing, but all the way when it is has not been homing
    The bed is 300x300 mm plus distance from homing to bed
    Best Regards
    Bo
    config.g
    ; Configuration file for Duet WiFi (firmware version 1.17)
    ; generated by RepRapFirmware Configuration Tool on Wed Oct 04 2017 09:46:19 GMT+0200 (Rom, sommertid)
    M111 S0 ; Debugging off
    G21 ; Work in millimetres
    M208 X-40 Y57 Z0 S1 ; Set axis minima
    M208 X300 Y300 Z300 S0 ; Set axis maxima
    M574 X1 Y2 Z1 S1 ; Define active high microswitches
    M558 P0 X0 Y0 Z0 H2 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
    G31 P600 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
    M557 X15:285 Y15:285 S20 ; Define mesh grid
    M569 P0 S0 ; Drive 0 goes backwards
    M569 P3 S0 ; Drive 3 goes backwords
    M350 X32 Y32 Z32 E32 I1 ; Configure microstepping with interpolation
    M92 X160 Y160 Z6400 E169.85138 ; Set steps per mm
    M203 X5000 Y5000 Z180 E800 ; Set maximum speeds (mm/min)
    M201 X1000 Y1000 Z20 E1000 ; Set accelerations (mm/s^2)
    M906 X1500 Y1500 Z1500 E1500 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M143 S260 ; Set maximum heater temperature to 260C
    M563 P0 D0 H1 ; Define tool 0
    M550 PBoson3DPrinter ; Set machine name
    M552 S1 ; Enable network
    M587 SBoson P"redsea01" ; Configure access point. You can delete this line once connected
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
Locked
