    Correct distance
    560
    • Heideundefined
      Heide
      What do I need to know to get the correct distance for X, Y and Z?
      It is a Voron build.
      Right now I have about 420 mm to a 300 mm board
      Voron CoreXY with Duet 3 + expansion + PanelDue 7i - 300 * 300 * 300 and Hemera Revo
      • fcwiltundefined
        fcwilt @Heide
        @heide said in Correct distance:
        Not sure what you mean by the "correct distance for X, Y and Z".
        Can you elaborate a bit?
        Thanks.
        Heideundefined 1 Reply Last reply Reply Quote 0
        • Heideundefined
          Heide @fcwilt
          @fcwilt Yeps, when X or Y travels 300 mm, the tool position is stated 420 mm
          • fcwiltundefined
            fcwilt @Heide
            Do you mean when starting at, say, X=0, a command to move 300mm actually moves 420mm?
            • Heideundefined
              Heide @fcwilt
              @fcwilt Yes that right
              • Heideundefined
                Heide @Heide
                @fcwilt of cause it only moves 300 mm. But the tool position says 420 mm
                • fcwiltundefined
                  fcwilt @Heide
                  I'm still confused.
                  The tool position of 420 is only meaningful if we know:
                  • the starting tool position
                  • the distance commanded to move
                  • Heideundefined
                    Heide @fcwilt
                    @fcwilt The bed is 300 X 300. The tool travels 300 mm. The Tool Position states that the travel was 420 mm.
                    • Heideundefined
                      Heide @Heide
                      @fcwilt I command the tool to travel 420 mm, it will only travel 300 actual mm. I need to command the tool 300 mm. and it will move 300 actuel mm.
                      • fcwiltundefined
                        fcwilt @Heide
                        Then you need to adjust the appropriate axis parameter in your M92 command.
                        New Axis Parameter Value = Current Axis Parameter Value * (420 / 300)
                        Repeat as needed to get satisfactory result.
                        • Heideundefined
                          Heide @fcwilt
                          @fcwilt Thanks, glad that I have a mesuring watch. It is dialed in 1 mm is actual 1 mm. Simpel equation, Nice
                          Heideundefined 1 Reply Last reply Reply Quote 1
                          • Heideundefined
                            Heide @Heide
                            Mark as solved
