    Duet 3 SBC and Connection via USB simultaneously
    • rabbit
      rabbit last edited by
      Hi can I use the Duet 3 with SBC (RaspberryPi) and a connection via USB with another PC simultaneously?
        I'm not sure... But if you do try it, be mindful of USB ground loops.
        https://docs.duet3d.com/en/User_manual/Overview/USB_ground_loops
          dc42 administrators @rabbit last edited by
          @rabbit yes that should work, but don't try to do send a print file through USB because the Pi won't know that you are doing a print from file. And be careful of ground loops.
