    State saved/restored when a macro runs
    Gcode meta commands
    • gloomyandyundefined
      gloomyandy
      Does anyone know if the details of what state (if any) is saved and restored when a macro is executed is documented anywhere? I've had a quick look but couldn't find anything.
        dc42 administrators @gloomyandy
        @gloomyandy it's these variables from GCodeMachineState:
        	float feedRate;
                uint32_t
        		selectedPlane : 2,
        		drivesRelative : 1,
        		axesRelative : 1,
        		volumetricExtrusion : 1,
        		g53Active : 1,							// true if seen G53 on this line of GCode
        		usingInches : 1,						// true if units are inches not mm
        		macroRestartable : 1,					// true if the current macro has used M98 R1 to say that it can be interrupted and restarted
        	Compatibility compatibility;				// which firmware we are emulating
        	uint8_t commandedQueueNumber;				// the queue number that was most recently commanded on this channel
          gloomyandy @dc42
          @dc42 Thanks David, do any of the "special" macros (like tool change, filament etc.) save/restore anything extra?
            @gloomyandy no, the only special thing about system macros (apart form being invoked automatically) is that they ignore workplace coordinate offsets.
