    No G-code command to return files like GET /rr_filelist ?
    402
    • Otsoundefined
      Otso
      I'm making a desktop app to control the Duet 2 WiFi for CNC use (WorkBee). I do all communication over telnet, except for listing files on the SD card for which I use HTTP. The reason is that GET /rr_filelist returns the information in a convenient format. I know there is M20 S2, but that is not as convenient, since it doesn't return files size or creation time, so I would have to make an additional call with M36 to get the details (all I care about is file size and date). On top of that, I can't find a way to get directory create time with any G-code, as M36 on a directory gives an error.
      My questions are:
      • Is there a way to get the same information as GET /rr_filelist over telnet/G-code, in case I have missed it?
      • If not, any plans to add it?
      • Is there any way to get directory create time over telnet/G-code?
      (Using a desktop app makes my workflow much easier, since no mouse clicking is needed, and I generally find usability to be better. This makes more of a difference for CNC use -- as opposed to 3D printing -- as you manually move the router around a lot more than with 3D printing, probing corners etc. My app is already usable, but still work in progress.)
      Sindariusundefined 1 Reply Last reply Reply Quote 1
      • Sindariusundefined
        Sindarius @Otso
        @otso You can use M20 to get a list of files.
        https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m20-list-sd-card
        Otsoundefined 1 Reply Last reply Reply Quote 0
        • Otsoundefined
          Otso @Sindarius
          @sindarius Did you read my post? 😉
          "I know there is M20 S2, but that is not as convenient, since it doesn't return files size or creation time"
          How do I get the creation time of a directory?
            dc42 administrators @Otso
            @otso try M20 S3.
            Otsoundefined 2 Replies Last reply Reply Quote 0
            • Otsoundefined
              Otso @dc42
              @dc42 Wow, thanks! Exactly what I was looking for! Maybe add that to the manual. 🙂
              I just finished implementing using M20 S2 and M36, but it should be easy enough to go "back" using M20 S3.
              Here's using M20 S2, M36, no directory date:
              • Otsoundefined
                Otso @dc42
                @dc42 It's no problem whatsoever, but I find it a little odd that both M20 S2 and S3 include the "Begin file list" and "End file list".
                Begin file list
                {"dir":"0:/gcodes/","first":0,"files":[{"type":"d","name":"Test","size":0,"date":"2022-03-14T00:48:18"},{"type":"f","name":"clock_contour.nc","size":5704,"date":"2022-03-10T19:47:08"}],"next":0}
                End file list
                I would expect a pure JSON response, like M36 and other commands that return JSON do. I can understand the header and footer for the text S0 response.
                dc42undefined 3 Replies Last reply Reply Quote -1
                  @otso yes that extra text is unintentional. I will log it for fixing in RRF 3.5.
                    @otso I think that text may go away if you use M555 to change the emulation mode from Marlin to RRF.
                    • Otsoundefined Otso marked this topic as a question
                    • Otsoundefined Otso has marked this topic as solved
                      @otso this is now fixed in the source code. The fix will be in RRF 3.5.0beta1 and in 3.4.1beta1.
