    DWC connection problem
    • Dogma2k
      Dogma2k last edited by
      Hi there i have a strange problem.
      when i load DWC in Safari the connecting dialog stays openned and doesn't allow me to interact with the interface.
      and if i had no connection and turn the printer off and on again i can access the DWC.
      But if I then close the browser and TAP and reopen them again, I can't access via DWC again. Only again if I switch the printer off and on again and used a new tap beforehand.
      Even if I have a connection to the PC and want to access the duet with my cell phone at the same time, the PC loses the connection and the cell phone cannot access it either.
      The firmware on the 6HC, 3HC and the DWC are flashed to 3.4.0.
      Does anyone have an idea why I have these problems
      • Dogma2k
        Dogma2k last edited by Dogma2k
        Here is some more information
        I used a Fritzbox 7290
        M122 befor crash
        m122
        RepRapFirmware for Duet 3 MB6HC version 3.4.0 (2022-03-15 18:57:24) running on Duet 3 MB6HC v1.01 or later (standalone mode)
        Board ID: 08DJM-9P63L-DJMSS-6J9DG-3SS6K-KBGBB
        Used output buffers: 1 of 40 (13 max)
        Static ram: 151000
        Dynamic ram: 96384 of which 24 recycled
        Never used RAM 103264, free system stack 200 words
        Tasks: NETWORK(ready,25.6%,251) ETHERNET(notifyWait,0.2%,168) HEAT(notifyWait,0.0%,321) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,797) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.9%,92) MAIN(running,66.3%,925) IDLE(ready,0.0%,30), total 100.0%
        Owned mutexes:
        Last reset 00:07:44 ago, cause: software
        Last software reset at 2022-04-03 22:26, reason: User, GCodes spinning, available RAM 103264, slot 2
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
        Error status: 0x00
        Step timer max interval 129
        MCU temperature: min 29.3, current 29.5, max 36.9
        Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
        12V rail voltage: min 12.2, current 12.3, max 12.4, under voltage events: 0
        Events: 0 queued, 0 completed
        Driver 0: standstill, SG min 0, mspos 8, reads 35490, writes 14 timeouts 0
        Driver 1: standstill, SG min 0, mspos 8, reads 35490, writes 14 timeouts 0
        Driver 2: standstill, SG min 0, mspos 8, reads 35490, writes 14 timeouts 0
        Driver 3: standstill, SG min 0, mspos 8, reads 35490, writes 14 timeouts 0
        Driver 4: standstill, SG min 0, mspos 8, reads 35490, writes 14 timeouts 0
        Driver 5: standstill, SG min 0, mspos 8, reads 35491, writes 14 timeouts 0
        Date/time: 2022-04-03 22:33:56
        Slowest loop: 7.31ms; fastest: 0.05ms
        === Storage ===
        Free file entries: 10
        SD card 0 detected, interface speed: 25.0MBytes/sec
        SD card longest read time 0.6ms, write time 0.0ms, max retries 0
        DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
        === MainDDARing ===
        === AuxDDARing ===
        Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
        Heater 1 is on, I-accum = 0.1
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0
        Aux2 is idle in state(s) 0
        Code queue is empty
        === CAN ===
        Messages queued 4182, received 3723, lost 0, boc 0
        Longest wait 0ms for reply type 0, peak Tx sync delay 314, free buffers 50 (min 49), ts 2325/2324/0
        Tx timeouts 0,0,0,0,0,0
        === Network ===
        Slowest loop: 2.49ms; fastest: 0.02ms
        Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
        HTTP sessions: 1 of 8
        - Ethernet -
        State: active
        Error counts: 0 0 1 0 0
        Socket states: 5 2 2 2 2 0 0 0
        m122 b1
        Diagnostics for board 1:
        Duet EXP3HC firmware version 3.4.0 (2022-03-15 08:59:40)
        Bootloader ID: SAME5x bootloader version 2.3 (2021-01-26b1)
        All averaging filters OK
        Never used RAM 158948, free system stack 200 words
        Tasks: Move(notifyWait,0.0%,160) HEAT(notifyWait,0.0%,108) CanAsync(notifyWait,0.0%,69) CanRecv(notifyWait,0.0%,82) CanClock(notifyWait,0.0%,71) TMC(notifyWait,7.5%,99) MAIN(running,91.1%,442) IDLE(ready,0.0%,39) AIN(delaying,1.3%,263), total 100.0%
        Last reset 00:08:45 ago, cause: software
        Last software reset data not available
        Driver 0: pos 0, 80.0 steps/mm,standstill, SG min 0, mspos 8, reads 55769, writes 11 timeouts 0, steps req 0 done 0
        Driver 1: pos 0, 80.0 steps/mm,standstill, SG min 0, mspos 8, reads 55770, writes 11 timeouts 0, steps req 0 done 0
        Driver 2: pos 0, 420.0 steps/mm,standstill, SG min 0, mspos 8, reads 55766, writes 16 timeouts 0, steps req 0 done 0
        Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
        Peak sync jitter -7/6, peak Rx sync delay 179, resyncs 0/0, no step interrupt scheduled
        VIN voltage: min 24.2, current 24.3, max 24.3
        V12 voltage: min 12.1, current 12.1, max 12.1
        MCU temperature: min 25.9C, current 26.1C, max 31.0C
        Last sensors broadcast 0x00000000 found 0 68 ticks ago, 0 ordering errs, loop time 0
        CAN messages queued 4231, send timeouts 0, received 4733, lost 0, free buffers 37, min 37, error reg 0
        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
        This is an M122 via USB that I did when I couldn't connect to the 6HC anymore
        m122
        Static ram: 151000
        Dynamic ram: 96384 of which 20 recycled
        Never used RAM 103268, free system stack 190 words
        Tasks: NETWORK(ready,25.9%,227) ETHERNET(notifyWait,0.1%,168) HEAT(notifyWait,0.0%,321) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,797) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.9%,92) MAIN(running,66.1%,925) IDLE(ready,0.0%,30), total 100.0%
        Owned mutexes: USB(MAIN)
        Last reset 00:17:05 ago, cause: power up
        Error status: 0x00
        Step timer max interval 131
        MCU temperature: min 30.0, current 39.9, max 40.1
        Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
        Driver 0: standstill, SG min 0, mspos 8, reads 10937, writes 14 timeouts 0
        Driver 1: standstill, SG min 0, mspos 8, reads 10937, writes 14 timeouts 0
        Driver 2: standstill, SG min 0, mspos 8, reads 10937, writes 14 timeouts 0
        Driver 3: standstill, SG min 0, mspos 8, reads 10937, writes 14 timeouts 0
        Driver 4: standstill, SG min 0, mspos 8, reads 10937, writes 14 timeouts 0
        Driver 5: standstill, SG min 0, mspos 8, reads 10937, writes 14 timeouts 0
        Date/time: 2022-04-03 23:14:12
        Slowest loop: 9.23ms; fastest: 0.05ms
        === Storage ===
        SD card longest read time 1.3ms, write time 0.0ms, max retries 0
        === MainDDARing ===
        === AuxDDARing ===
        Segments left: 0
        USB is ready with „m122“ in state(s) 0
        Code queue is empty
        === CAN ===
        Messages queued 9230, received 8213, lost 0, boc 0
        Longest wait 1ms for reply type 6042, peak Tx sync delay 6, free buffers 50 (min 49), ts 5130/5129/0
        === Network ===
        Slowest loop: 10.83ms; fastest: 0.02ms
        HTTP sessions: 0 of 8
        - Ethernet -
        State: active
        Error counts: 0 0 0 0 0
        Socket states: 2 2 2 2 2 0 0 0
        ok
        M552
        Ethernet is enabled, configured IP address: 0.0.0.0, actual IP address: 192.168.178.41
        After that I made an M111 P1 S1.
        But I still couldn't connect to the Duet. It only worked again when I restarted it.
        M111 P1 S1
        Debugging enabled for modules:
        Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) WiFi(14) Display(15) SbcInterface(16) CAN(17)
        Debugging enabled for modules: Network(1 - 0xffffffff)
        Debugging disabled for modules: Platform(0) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) WiFi(14) Display(15) SbcInterface(16) CAN(17)
          You're not the first person to have strange behaviour with Fritzbox routers, but I don't know why that may be.
          When you're unable to connect to DWC are you able to ping the IP address assigned to the Duet?
          Just in case it's SD card issue, do you have a spare to test with?
