    configuration problem CR10S + V6 Volcano
    Example setups and prints
    • alekovic3d
      alekovic3d last edited by
      Hello everyone, I'm Spanish, excuse my English...
      I have a CR10S, 1 year ago I installed the Duet 2 wifi, 1 month ago I made a modification installing MGN Guides and Trianglelabs V6 Volcano direct extruder, currently I am adjusting the movements of the machine since it does not print correctly.
      Could someone who has a CR10S with V6 show me his config.g file? I've modified my parameters so much that I don't even know what I'm doing anymore...
      My current parameters are:
      config.g
      M566 X600.00 Y600.00 Z20.00 E2000.00 ; JERK set maximum instantaneous speed changes (mm/min)
      M203 X10800.00 Y10800.00 Z300.00 E3000.00 ; set maximum speeds (mm/min)
      M201 X6000.00 Y6000.00 Z300.00 E5000 ; set accelerations (mm/s^2)
      M204 P600 T4000 ; print and travel acceleration
      M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M593 F20 ; FRECUENCIA GHOSTING
      Thank you all for the trouble
        Can you be more specific about what isn't working correctly?
        Perhaps you should start with a clean config file from the online tool.
        https://configtool.reprapfirmware.org/Start
