    How can i add macro that run same movement
    Gcode meta commands
    • hareshPrajapati
      hareshPrajapati last edited by
      I need macro or Gcode that run same movement for particular time
      i mean if i send command like M98 P''mymacro.g" S30 than command
      can run for 30 seconds repeatedly (approx. 15 time in 30 seconds) .
      mymacro.g file contains :
      G1 X75
      G1 X50
      I m using old version of reprap and that doesn't support meta commands and also I don't need it
      please, help as I new in the forum.
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @hareshPrajapati last edited by
        @hareshprajapati short answer is you can't with the old version and you'll definitely need RRF 3.3 or 3.4 to be able to do iterations
        hareshPrajapati 1 Reply Last reply Reply Quote 0
        • hareshPrajapati
          hareshPrajapati @jay_s_uk last edited by
          @jay_s_uk Can you please explain in short
          How we do iterations using R.R.F 3.4?
            https://docs.duet3d.com/en/User_manual/Reference/Gcode_meta_commands
            • Moved from General Discussion by  Phaedrux Phaedrux
