    Meaning of move.axes[n].homed
    Gcode meta commands
    • hlwerschner
      hlwerschner last edited by
      The documentation simply states that the value of "move.axes[n].homed" reflects the "homed state" of that axis. Does this mean:
      (a) At some time BEFORE inspecting this value, there was a gcode "G28 X" for n = 0 resp G28 Y or G28 Z done which caused a homing to be executed somwhow.
      or
      (b) the respectiv axis is "homed"
      i.e. its current position == move.axes[n].min
      I am a bit unsure what "homed" really means ... and how long it is valid. The only experience I have is that M999 or a gcde that stops axis motors, will set homed = false.
      I have several macros where I assumed that homed = true implies that the current axis position = at the min axis position AND that the endstop switch would be triggered /when defined) for the min pos).
      Is it perhaps better to check for the endstop state also?
        dc42 administrators @hlwerschner last edited by
        @hlwerschner it means that the firmware knows the position of that axis, because that axis has previously had a homing procedure run and the motor has not been turned off since then.
        hlwerschner 1 Reply Last reply Reply Quote 0
        • hlwerschner
          hlwerschner @dc42 last edited by
          @dc42 Ah yes, that clarifies. So the position of that axis may be any value.
          • mikeabuilder
            mikeabuilder last edited by
            The location of an axis is found with this
            move.axes[n].machinePosition
            Returns null if the position is unknown (machine not homed).
