short to ground issues
About 2 weeks ago the end stop in io4 quit working moved it to io3 and it worked again. Though that strange but it was working. Today about 5 layers into a print I get.
4/6/2022, 4:22:17 PM Error: short-to-ground reported by driver(s) 0
Error: over temperature shutdown reported by driver(s) 0
Warning: high temperature reported by driver(s) 0
4/6/2022, 4:22:12 PM Error: short-to-ground reported by driver(s) 0and the error just kept scrolling. My printer has been working just fine since it was put together. I only made one change since it was assembled and that was to change from an inductive probe to a euclid, but that was all done in the 1lc. here is the M122 and my config.g
4/6/2022, 4:44:05 PM M122
RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus WiFi (standalone mode)
Board ID: Q4QR2-4196U-D65J0-40KMS-J703Z-RRM35
Used output buffers: 3 of 40 (14 max)
Static ram: 102724
Dynamic ram: 107004 of which 24 recycled
Never used RAM 31096, free system stack 130 words
Tasks: NETWORK(ready,15.6%,226) HEAT(delaying,0.0%,348) Move(notifyWait,0.1%,283) CanReceiv(notifyWait,0.0%,773) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,347) TMC(delaying,1.2%,115) MAIN(running,82.3%,412) IDLE(ready,0.0%,29) AIN(delaying,0.8%,264), total 100.0%
Owned mutexes:
Last reset 00:19:58 ago, cause: software
Last software reset at 2022-04-06 16:24, reason: User, GCodes spinning, available RAM 30488, slot 0
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
Error status: 0x00
Aux0 errors 0,0,0
MCU revision 3, ADC conversions started 1199105, completed 1199105, timed out 0, errs 0
Step timer max interval 953
MCU temperature: min 28.6, current 29.2, max 33.3
Supply voltage: min 23.9, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
Heap OK, handles allocated/used 99/5, heap memory allocated/used/recyclable 2048/232/162, gc cycles 0
Driver 0: position 26488, standstill, SG min/max 0/398, read errors 0, write errors 1, ifcnt 152, reads 43401, writes 19, timeouts 0, DMA errors 0
Driver 1: position 2488, standstill, SG min/max 0/88, read errors 0, write errors 1, ifcnt 152, reads 43401, writes 19, timeouts 0, DMA errors 0
Driver 2: position 340, standstill, SG min/max 0/84, read errors 0, write errors 1, ifcnt 152, reads 43401, writes 19, timeouts 0, DMA errors 0
Driver 3: position 0, standstill, SG min/max 0/84, read errors 0, write errors 1, ifcnt 152, reads 43401, writes 19, timeouts 0, DMA errors 0
Driver 4: position 0, standstill, SG min/max 0/10, read errors 0, write errors 1, ifcnt 149, reads 43402, writes 18, timeouts 0, DMA errors 0
Driver 5: position 0, standstill, SG min/max 0/10, read errors 0, write errors 1, ifcnt 150, reads 43402, writes 18, timeouts 0, DMA errors 0
Driver 6: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 79, reads 43411, writes 9, timeouts 0, DMA errors 0
Date/time: 2022-04-06 16:44:01
Cache data hit count 2196188892
Slowest loop: 12.26ms; fastest: 0.07ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.5ms, write time 0.0ms, max retries 0
DMs created 83, maxWait 433726ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 66, completed moves 66, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 51], CDDA state -1
=== AuxDDARing ===
Bed heaters = 0 -1, chamberHeaters = -1 -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== CAN ===
Messages queued 10827, received 14393, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 368, free buffers 17 (min 15), ts 5994/5993/0
Tx timeouts 0,0,0,0,0,0
=== Network ===
Slowest loop: 22.78ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.26
WiFi MAC address f0:08:d1:02:e5:af
WiFi Vcc 3.33, reset reason Power up
WiFi flash size 2097152, free heap 22528
WiFi IP address 192.168.1.19
WiFi signal strength -40dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
I have not been able to get the error to show up by moving it manually.
- WiFi -
@motor5622 said in short to ground issues:
I think you're in stealthchop mode and moving too fast for it.
I suggest you update to 3.4 which defaults to spreadcycle mode and see if it makes a difference.
Since you're able to move the motor manually I don't think it's an actually failed driver.
Is there anything that needs to change right away in config.g moving to 3.4? I haven't looked to deep into the upgrade yet.
